feucar Posted April 18, 2006 Share Posted April 18, 2006 Hi all, i'm using DVBViewer with a skystar 2 pci card equipped with the 4.4.0 driver. If i use the technisat version (bundle with 4.4.0 drier) i get epg data on italian channel (eg RAI 1); epg data for the same channel on Pro (3.2.6.80) version is missing. any idea ? Thanks a lot Quote Link to comment
hdv Posted April 18, 2006 Share Posted April 18, 2006 Hallo, you must make a new channellist for the ProVersion, because the Pro need some informations in the channellist to receive epg which are not in the channellist of the technisat version. with this channel-editor from this site you can make your own list really easy, in short time. Quote Link to comment
feucar Posted April 19, 2006 Author Share Posted April 19, 2006 Hi, i've removed and reinstalled the pro version then i've manually modified a channel to make the Pro parameters equals to TE one's. Now i correctly tune the channel but still without EPG data as you can see in attachment. I don't understand. Thanks for help Quote Link to comment
hdv Posted April 19, 2006 Share Posted April 19, 2006 (edited) Hallo, please use the option "Automatic Channel Data Update" if you tune a channel then it update the channellist for this channel, click through every channel for update this or make a channelscan with the option "Scan & Update" please make a backup of the file channel.dat in your installation-folder from DVBViewer pro, before you scan, who knows what happens. Edited April 19, 2006 by hdv Quote Link to comment
feucar Posted April 20, 2006 Author Share Posted April 20, 2006 Ok, a full scan solve the problem. Thank you for your kind assistance. Quote Link to comment
