Foxmul Posted May 9, 2006 Share Posted May 9, 2006 Hi I used the Pro version, and when I changed channel I saw the number changing on the EPG on the bottom of the screen. Using the beta version instead, when changin channel the number appears on the high-left side of the screen, and not more un the coloured EPG on bottom. It's a my bad configuration or is the right functionning? regards Quote Link to comment
Guest Lars_MQ Posted May 9, 2006 Share Posted May 9, 2006 I'm pretty sure the numbers where always on the top left in the default skin. At least I designed it this way . Quote Link to comment
Foxmul Posted May 9, 2006 Author Share Posted May 9, 2006 I'm pretty sure the numbers where always on the top left in the default skin. At least I designed it this way . <{POST_SNAPBACK}> I dreamed?!?!? I'm sure that pressing the sequence on the remote "1-2-5" on the OSD on bottom appeared at the pressure of the fisrst digit the name of the channel nr.1, then after the pressing of the second digit ('2') appeared the channel stored on position 12 and the third pressure ('5') the channel stored on 125 ... All in the OSD on the bottom.....! ??? Quote Link to comment
