janfin Posted May 9, 2006 Share Posted May 9, 2006 Hello! I have purchased DVBViewer pro and downloaded it (v3.2.6). Now when I'm installing that, durin installation (about progressbar location 80-100%) I get error message. Anyhow installation continues until it asks if I want to start DVBViewer now. DVBViewer don't start at all, I got same error if I try to start it (look attachment). os: xpsp2, with latest updates mainboard: via epia M10000 I have tryed with and without DVB card installed. Same situation. What should I do for troubleshoot this? DVBViewer log file is attached below. - Jan 8.5.2006 22:37:22 EAccessViolation raised by instance frmOptions of class TfrmOptions at 006BFB45:Zugriffsverletzung bei Adresse 006BFB45 in Modul 'DVBViewer.exe'. Lesen von Adresse 00000000 8.5.2006 22:37:32 EAccessViolation raised by instance Panel1 of class TPanel at 0067E65A:Zugriffsverletzung bei Adresse 0067E65A in Modul 'DVBViewer.exe'. Lesen von Adresse 00000000 8.5.2006 22:44:35 EAccessViolation raised by instance frmOptions of class TfrmOptions at 006BFB45:Zugriffsverletzung bei Adresse 006BFB45 in Modul 'DVBViewer.exe'. Lesen von Adresse 00000000 8.5.2006 22:45:27 EAccessViolation raised by instance frmOptions of class TfrmOptions at 006BFB45:Zugriffsverletzung bei Adresse 006BFB45 in Modul 'DVBViewer.exe'. Lesen von Adresse 00000000 8.5.2006 22:53:05 EAccessViolation raised by instance frmOptions of class TfrmOptions at 006BFB45:Zugriffsverletzung bei Adresse 006BFB45 in Modul 'DVBViewer.exe'. Lesen von Adresse 00000000 8.5.2006 22:53:15 EAccessViolation raised by instance Panel1 of class TPanel at 0067E65A:Zugriffsverletzung bei Adresse 0067E65A in Modul 'DVBViewer.exe'. Lesen von Adresse 00000000 Quote Link to comment
yaRincewind Posted May 10, 2006 Share Posted May 10, 2006 Please look at this post http://www.DVBViewer.com/forum/index.php?showtopic=3247 At the end there is a download link. Please put this program in your DVBViewer folder, execute it and post the resulting ZIP archive here in the forum. Quote Link to comment
janfin Posted May 10, 2006 Author Share Posted May 10, 2006 Here it comes. Please look at this post http://www.DVBViewer.com/forum/index.php?showtopic=3247 At the end there is a download link. Please put this program in your DVBViewer folder, execute it and post the resulting ZIP archive here in the forum. <{POST_SNAPBACK}> support.zip Quote Link to comment
Guest Lars_MQ Posted May 10, 2006 Share Posted May 10, 2006 You should consider installing a mpeg2 decoder. Without the DVBViewer wont work. Quote Link to comment
