lunkan Posted May 19, 2006 Share Posted May 19, 2006 (edited) If I use the favourite channel list I want the channels in EPG to show up in the same order as in the favourite list. (or group in favorites) Edited May 19, 2006 by lunkan Quote Link to comment
steffenvogel Posted May 19, 2006 Share Posted May 19, 2006 Simply copy the channels from your channel to your favorites. mfg Steffen Quote Link to comment
esperado Posted May 22, 2006 Share Posted May 22, 2006 (edited) If I use the favourite channel list I want the channels in EPG to show up in the same order as in the favourite list. (or group in favorites) <{POST_SNAPBACK}> +1. AND a way to edit the channels number in Channels list ? They are numbered in the order they are found by the scan ? Edited May 22, 2006 by esperado Quote Link to comment
hdv Posted May 22, 2006 Share Posted May 22, 2006 Hallo esperado, in the Pro or the GE Version with drag&drop in the channellist, or very simple with the Channel Editor that you can find on this site. Quote Link to comment
esperado Posted May 23, 2006 Share Posted May 23, 2006 in the Pro or the GE Version with drag&drop in the channellist, or very simple with the Channel Editor that you can find on this I've done it, but you loose some infos: Providers, for an example, if you just list the channels in the absolute order you want. What i would like is to get, for each channel: frequenciy, provider, and custom numbering of the channels, like in favourite. Then, a preset witch shows the Channel list ordered by provider/frequency/custom number. See what i mean. But, more that all, a way to can call from my keyboard or remote channels/favourite numbered more than 9. May-be it is possible, but i have not found the way to do that. Quote Link to comment
