newmark Posted May 20, 2006 Posted May 20, 2006 Hello, i have a serious problem, i have a centralized satellite antenna on Hotbird, I also have a skystar2 USB DVB on XP and progdvb (last driver and last version) When i serach channels it find something like 300 channels, the signal for the great part of those channel is 29% but on some i get 50/60%. I don't see ANY channel, on some i can hear voice but no video, someone has told me that on the LNB setting i have to uncheck power beacause of centralized antenna, but nothing happen, i have also buyed a signal amplifier for satellite, but does not change anything. The cable is unique, no other DVB or anything attached on the line. the cable has a collector in 2 part (from the entrance i have 3 patch to reach the wall). There is something to set if i have a centralized antenna more than "power" check? may be the problem the mpeg codec? it's possible even if more than half channels does not get neither the sound? thanks Quote
Guest Lars_MQ Posted May 20, 2006 Posted May 20, 2006 I suggest you visit the forum of progdvb. This is the Forum of DVBViewer Pro and not the Technisat or progdvb support. No DVBViewer related question -> moved. Quote
