pkorim Posted May 22, 2006 Share Posted May 22, 2006 Hey people When I run DVBViewer public beta with FireDTV/S CI It works well with free channels even with HDTV Channels. When I try to watch the encrypted channels, it does not work. The "Show CAM" menu item is disabled In MyTheater all encrypted channels work fine. this does not depent on the running of the FireDTV CI tool. Regards, Petersupport.zip Quote Link to comment
Derrick Posted May 22, 2006 Share Posted May 22, 2006 What CI module and which channels? Quote Link to comment
pkorim Posted May 22, 2006 Author Share Posted May 22, 2006 What CI module and which channels? <{POST_SNAPBACK}> Cryptoworks @ ASTRA 1D 23,5 E freq 12525MHz vertical SR 27500 and freq 12565MHz horiz. SR 27500 Quote Link to comment
Derrick Posted May 22, 2006 Share Posted May 22, 2006 Sorry, I don't have a clue. Quote Link to comment
pkorim Posted May 22, 2006 Author Share Posted May 22, 2006 Sorry, I don't have a clue. <{POST_SNAPBACK}> do u really think it depend on the type of CI Module? hm I do not think so Quote Link to comment
Derrick Posted May 22, 2006 Share Posted May 22, 2006 Does the module/card work in a "normal" ci_stb? I only can guess that you'll need the mmi which is not fully implemented. I don't have CW.. ..use mytheatre for the time being Quote Link to comment
pkorim Posted May 23, 2006 Author Share Posted May 23, 2006 Does the module/card work in a "normal" ci_stb? I only can guess that you'll need the mmi which is not fully implemented. I don't have CW.. ..use mytheatre for the time being <{POST_SNAPBACK}> yes it works in a "normal" ci_stb as well - it is HUMAX 9100 CI module is (click to see) Philips CI Cryptoworks Module so it is not noname I have another one : Satforce CA-Modul easy.TV none of them work with DVBViewer. I don't know how mmi would help the program (DVBViewer) use the hardware (CA Module) while MMI meaning is Man-Machine Interface. On the other hand of course the Modules are accessible through FireDTV CI tool , but there is no description what should I set up with DVBViewer. With MyTheater and with Humax I don't need to set up anything IS IT POSSIBLE FOR Lasr_MQ or Griga TO ANSWER WHILE THEY HAVE EXPERIENCES WITH FireDTV? Thank You, Regards Quote Link to comment
schmchr Posted July 2, 2006 Share Posted July 2, 2006 (edited) Hi, i had a similar problem with my FireDtv C (with Alpacrypt CAM). It's gone since i disabled the "Jugendschutz" (sorry don't know the correct translation). The deafult was FSK16, i changed it to "OFF".... Maybe this helpds you. Edited July 2, 2006 by schmchr Quote Link to comment
Guest Lars_MQ Posted July 2, 2006 Share Posted July 2, 2006 IS IT POSSIBLE FOR Lasr_MQ or Griga TO ANSWER WHILE THEY HAVE EXPERIENCES WITH FireDTV? Nope not possible, don't own a fireDTV and have no cam nor subscription Quote Link to comment
