mlehtola Posted May 22, 2006 Share Posted May 22, 2006 Hi, there's a menu above the teletext screen to handle pages with mouse, but when you are using full screen mode it disappears. I'm using only mouse (OSD) to handle DVBV (it's faster and gives more options than rc), so it's basicly impossible to use teletext. You can have the menu when you start teletext when you're not in full screen mode and then make the window maximized, but the menu is too small to use. I would like to have that menu in full screen mode as well. Otherwise, what a great piece of software! Thanks. regards Markku Quote Link to comment
Guest Lars_MQ Posted May 22, 2006 Share Posted May 22, 2006 what menu are you talking about? Quote Link to comment
mlehtola Posted May 22, 2006 Author Share Posted May 22, 2006 what menu are you talking about? <{POST_SNAPBACK}> This one, would be nice to have with bigger button in full screen: Regards Markku Quote Link to comment
Guest Lars_MQ Posted May 22, 2006 Share Posted May 22, 2006 this is not the OSD teletext, you said you're using osd? the buttons of tghe teletext window can not be changed in size. Quote Link to comment
mlehtola Posted May 23, 2006 Author Share Posted May 23, 2006 1. I start DVBViewer with "full screen" option on 2. I start OSD menu by pressing mouse wheel 3. I select "Teletext" from the menu 4. I do not have any menu like in the picture above -> I cannot use Teletext with mouse Sorry if I missed something (quite beginner with this kind of stuff) Quote Link to comment
