mr_chaela Posted May 23, 2006 Share Posted May 23, 2006 Help. How do I get out of HTPC mode, I can't find a way of accessing the options panel in HTPC mode to switch back to windowed mode. tia Quote Link to comment
hdv Posted May 23, 2006 Share Posted May 23, 2006 Hallo, go in the OSD menu -> htpcHome -> theSettings -> Unlock HTPC-Mode Quote Link to comment
mr_chaela Posted May 23, 2006 Author Share Posted May 23, 2006 (edited) Thanks for quick reply but I don't seem to be able to do that. I'm running winxp with just a mouse, can't access the OSD. Problem solved, thanks for help. Edited May 23, 2006 by mr_chaela Quote Link to comment
Foxmul Posted May 24, 2006 Share Posted May 24, 2006 Thanks for quick reply but I don't seem to be able to do that.I'm running winxp with just a mouse, can't access the OSD. Problem solved, thanks for help. <{POST_SNAPBACK}> How did you solve? I have the same problem... Quote Link to comment
kenso Posted June 13, 2006 Share Posted June 13, 2006 Hey there... I have the same problem... and a can't get my DVBViewer to enter OSD... any ideas? Quote Link to comment
markus23 Posted June 13, 2006 Share Posted June 13, 2006 with default settings, just press O (the letter, not the number ) and there you can change your settings... Quote Link to comment
mlehtola Posted June 13, 2006 Share Posted June 13, 2006 (edited) Middle button/wheel gives you the OSD-menu (default behavior) Edited June 13, 2006 by mlehtola Quote Link to comment
