djhandz Posted May 29, 2006 Share Posted May 29, 2006 need help in finding channels i set it to terrestrial and then scan but i am not getting any channels please help me Quote Link to comment
esperado Posted May 29, 2006 Share Posted May 29, 2006 need help in finding channels i set it to terrestrial and then scan but i am not getting any channels please help me <{POST_SNAPBACK}> What is your country ? Try to change the frequencies in your DVBViewer\transponders\Europe.ini from: X=XXX000,X to X=XXX167,X (using replace "000," with "167,") Is -it better ? Quote Link to comment
djhandz Posted May 29, 2006 Author Share Posted May 29, 2006 (edited) i can not see any numbers relating to the ones you stated Edited May 29, 2006 by djhandz Quote Link to comment
esperado Posted May 29, 2006 Share Posted May 29, 2006 i can not see any numbers relating to the ones you stated <{POST_SNAPBACK}> Europe.ini is in the folder indicated. In DVBViewer installation. (not transedit) Quote Link to comment
djhandz Posted May 29, 2006 Author Share Posted May 29, 2006 (edited) i looked in the DVBViewer installation can i not download a ini file from somewhere i have attached a copy ov my ini file please take a look thankyou Copy_of_Europe.ini Edited May 29, 2006 by djhandz Quote Link to comment
djhandz Posted May 29, 2006 Author Share Posted May 29, 2006 sorted am nice now Quote Link to comment
esperado Posted May 29, 2006 Share Posted May 29, 2006 sorted am nice now Not understud. Did-it work with the modif i told-you ? And what is your country ? Your confirmation is to confirm for the devs. Quote Link to comment
