gabier Posted May 31, 2006 Posted May 31, 2006 Hello everybody Sorry for English, but I am not good at all when writing in German. I would like to use DVBViewer with a Hauppauge WinTV-Nova-T-USB2. The official compatibility list does not mention it. It mentions only WinTV-Nova-T-PCI. But Hauppauge specialists told me that DVBViewer works now with Nova-T-USB2. So I downloaded the DVBViewer free edition to find out and clicked on "setup.exe". Well now, the setup exits with the error message : "The card driver must be installed before installing the application software....." The driver is indeed installed for it works with the native Hauppauge viewer/recorder WinTV2000. My question is : is there a special setup procedure for standalone DVB-T tuners or does DVBViewer definitely not support Hauppauge WinTV-Nova-T-USB2 ? Gabier Quote
putte@putte.net Posted May 31, 2006 Posted May 31, 2006 (edited) It works. Go to settings->options->DirectX and change current device to Hauppauge. And Viola' On pro version that is BR Patrik Edited May 31, 2006 by putte@putte.net Quote
gabier Posted May 31, 2006 Author Posted May 31, 2006 It works.Go to settings->options->DirectX and change current device to Hauppauge. And Viola' On pro version that is Patrick, Thank you for your advice. At the moment I have no "settings" menu as DVDViewer cannot install itself. Do you mean it does not install because the free edition is the Technisat edition ? And that if I buy the regular edition I can be sure that it will work ? Gabier Quote
hdv Posted May 31, 2006 Posted May 31, 2006 Hallo, you can try a tool, Transedit MMC, you can find it on this site, http://www.DVBViewer.com/en/index.php?page=downloads if it work, you can buy the DVBViewer Pro the free DVBViewer TE that you have downloaded can only use TechniSat DVB-Cards look here for Purchasing the full version Quote
gabier Posted June 2, 2006 Author Posted June 2, 2006 you can try a tool, Transedit MMC, you can find it on this site ...if it work, you can buy the DVBViewer Pro... the free DVBViewer TE that you have downloaded can only use TechniSat DVB-Cards ... Thank you hdv. Several people told me it does work, so I bought the full version, and indeed it works Gabier Quote
Klausing Posted June 4, 2006 Posted June 4, 2006 a list of from user reportet working cards you can find here: http://www.steffen-klausing.de/content4/fa...=144&artlang=de Quote
