MrMartino Posted June 2, 2006 Share Posted June 2, 2006 Hello! I just bought DVBViewer recently and installed the latest beta, but end up with "0 channels found" after having done a scan... Im using FireDTV-T (throu firewire) and live in sweden. My friend has almost the same HTPC setup and same tv-card (also same tv provider) and his DVBViewer finds all channels. It seems very strange because im also using FireDTV with Mediaportal and MCE and i have never had any problems finding channels with those applications and they still works great now... I bought DVBViewer because of the HDTV support (since football World Cup will be broadcasted in h264 here in sweden in a few days, but now i dont know what to do anymore Seems like ive tried everything. Few hours ago i kept getting a "Hardware Not available" everytime i started the program, but now the message dont show up anymore atleast Here is my configuration: Settings>Options>Hardware: -------------------------------- FireDVT BDA Tuner DVBT Tuner Type Terrestial State: Preferred Stop Stream while tuning (ON) Has CI module (ON) DIrectX: ............ Tried all kinds of codecs (nvidia, dscaler, mpv...) with no difference Channel Scan: ---------------- Reception Type: Terrestial Transponder List: EUR My HTPC setup is: -------------------- P4 3.0Ghz HT 512Mb RAM GF 6600GT & Directx 9c Windows Media Center Edition + all needed updates and patches. FireDTV drivers 4.3.3.0 Would really appretiate some help... Thanks in advance Martin Sweden Quote Link to comment
Guest Lars_MQ Posted June 2, 2006 Share Posted June 2, 2006 Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 Quote Link to comment
MrMartino Posted June 2, 2006 Author Share Posted June 2, 2006 Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 <{POST_SNAPBACK}> Oh sorry i didnt read the rules... Here is my support.zip file created with the support-tool. support.zip Also i think i forgot to tell that im using the latest beta. Hope it helps... Martin Quote Link to comment
esperado Posted June 2, 2006 Share Posted June 2, 2006 Can-you try this, and tell if it is working ? http://www.DVBViewer.com/forum/index.php?showtopic=12776 Quote Link to comment
MrMartino Posted June 2, 2006 Author Share Posted June 2, 2006 Can-you try this, and tell if it is working ? http://www.DVBViewer.com/forum/index.php?showtopic=12776 <{POST_SNAPBACK}> I just tried that but no difference Still finding nothing... But thanks anyway! All hints are appretiated. Martin Quote Link to comment
Griga Posted June 2, 2006 Share Posted June 2, 2006 My friend has almost the same HTPC setup and same tv-card (also same tv provider) and his DVBViewer finds all channels. What about using your friend's channellist? It's the file channels.dat, but both of you have to check where it is located - it depends on the User Mode. Read more about it here. Quote Link to comment
improwise Posted June 3, 2006 Share Posted June 3, 2006 My friend has almost the same HTPC setup and same tv-card (also same tv provider) and his DVBViewer finds all channels. What about using your friend's channellist? It's the file channels.dat, but both of you have to check where it is located - it depends on the User Mode. Read more about it here. <{POST_SNAPBACK}> I can confirm that FireDTV works with the latest DVBViewer Pro, ie the premium version. As far as I know, it wont work with the free TE reason (for obvious reasons). Please make sure you use driver 2.3 for Fire/FloppyDTV and that you have the correct ones installed, the ones for boxer and not the general ones included with MyTheatre (this only applies to DVB-T in sweden). /pJ Quote Link to comment
procash Posted June 6, 2006 Share Posted June 6, 2006 A few days ago I made a new installation of Windows XP and had a similar problem. I only installed the BDA driver (without MyTheatre) and DVBViewer did not work. The reason: Because I use the Common Interface, I had to start the „CommonInterface.exe“ which will be installed with the FireDTV BDA drivers. After starting the program I entered my Smartcard PIN, and switches off all restrictions. Now DVBViewer is working well with FireDTV. Maybe you give it a try (if you are using the CI, too). Quote Link to comment
LiMiT Posted June 6, 2006 Share Posted June 6, 2006 (edited) I only installed the BDA driver (without MyTheatre) and DVBViewer did not work. The reason: Because I use the Common Interface, I had to start the „CommonInterface.exe“ which will be installed with the FireDTV BDA drivers. <{POST_SNAPBACK}> The latest version of the BDA drivers for FDTV does not include the CI-application as an external program. Instead, this is installed as a system driver. DVBViewer should work without the CI-application active in the system tray, provided that you are running the latest FDTV drivers. Edited June 6, 2006 by LiMiT Quote Link to comment
procash Posted June 7, 2006 Share Posted June 7, 2006 I don’t know what you mean. I installed the latest drivers (BDA Setup Version 2.3 Light) from digital-everywhere homepage and after installation the application “CommonInterface.exe” was available. Only after starting this program once, I could use the FireDTV also with DVBViewer (when the CI is plugged in). But I agree, after that “initialization” there is no need for this application. Quote Link to comment
