bilbo Posted June 12, 2006 Share Posted June 12, 2006 (edited) Hi All, Hope someone can help! Got my TT1500 budget set up, and did a scan using dvb ge, found the bbc hd transmissions, but when I select the channel, I get a box with 'cannot render mediafile/output pin, error:0x80004005 (unknown error code) Anyone able to offer any help? I've got the PDVD trial version installed, as well as other stuff, but where do I start looking? Cheers! Dave EDIT: Let me add this: support.zip Edited June 12, 2006 by bilbo Quote Link to comment
jf2020 Posted June 12, 2006 Share Posted June 12, 2006 Hi All,Hope someone can help! Got my TT1500 budget set up, and did a scan using dvb ge, found the bbc hd transmissions, but when I select the channel, I get a box with 'cannot render mediafile/output pin, error:0x80004005 (unknown error code) Anyone able to offer any help? I've got the PDVD trial version installed, as well as other stuff, but where do I start looking? Cheers! Dave EDIT: Let me add this: <{POST_SNAPBACK}> According to your support files you're still using the last stable version 3.2.6.80. To get support for H264 (BBCHD) you need to use the latest beta that also include the latest dvbsource. Plaese read the included readme! Also notice that you need a (very) powerful PC... Quote Link to comment
bilbo Posted June 12, 2006 Author Share Posted June 12, 2006 Thankyou scanning now... Quote Link to comment
memmerson Posted June 12, 2006 Share Posted June 12, 2006 Hi all, DVBViewer newbie here! I'm having the exact same problem as bilbo but I am running 3.4.12.1. This really has me stumped I been trying to get this working all evening to no avail. I am using Coreavc 1.1 with a terratec 2400i. Any ideas anyone? Thanks, Marc Quote Link to comment
brightside Posted June 12, 2006 Share Posted June 12, 2006 Hi all, DVBViewer newbie here! I'm having the exact same problem as bilbo but I am running 3.4.12.1. This really has me stumped I been trying to get this working all evening to no avail. I am using Coreavc 1.1 with a terratec 2400i. Any ideas anyone? Thanks, Marc <{POST_SNAPBACK}> I suppose you can get the SD bbc channels to display OK so your basic system setup (Card, drivers, DVBViewer etc.) is OK. In this case have you installed the H.264 kit from the members area? Without this you can't do much with the BBC HD stream. Quote Link to comment
Klausing Posted June 13, 2006 Share Posted June 13, 2006 In the last version of DVBViewerGE is h.264 integratet Quote Link to comment
memmerson Posted June 13, 2006 Share Posted June 13, 2006 Hi all, thanks for the replies. SD streams are indeed working ok. I have installed DVBViewer version 3.2.6 (not DVBViewer GE, should I be using GE?) I then copied the files for 3.4.12.1 (beta) on top of the original installation. Corecodec is specified as the h.264 video codec and ac3filter for audio. Audio is working ok on the HD channels. I haven't installed the h.264 kit, is this necessary if I am not running GE? What is the difference between the GE and non-GE versions? Thanks again, Marc Quote Link to comment
Griga Posted June 13, 2006 Share Posted June 13, 2006 I haven't installed the h.264 kit, is this necessary if I am not running GE? It is sufficient to install DVBViewer Filter 2.8 from the members area, plugins section, that is capable of demultiplexing H.264 streams. The H.264 Kit provides two additional tools for analyzing / playing H.264 streams, and the ReadMe contains some hints (in case you want to dive deeper into this matter). Quote Link to comment
memmerson Posted June 13, 2006 Share Posted June 13, 2006 Many thanks, I will try this tonight when I get home from work. Regards, Marc Quote Link to comment
