KidCactus Posted June 14, 2006 Share Posted June 14, 2006 Is there a way to set a delay for the audio? Right now I have a slight delay in the video, so I need to adjust the audio to sync to the video. Quote Link to comment
Guest Lars_MQ Posted June 14, 2006 Share Posted June 14, 2006 Maybe you should try the fix the root of the problem options -> directX try other decoders. Quote Link to comment
KidCactus Posted June 14, 2006 Author Share Posted June 14, 2006 Maybe you should try the fix the root of the problem options -> directX try other decoders. <{POST_SNAPBACK}> I've tried several different audio decoders, but the problem persists. But I just realized I can set the audio to FFDShow and use it's internal delay. I hope that will do the trick. Quote Link to comment
steffenvogel Posted June 14, 2006 Share Posted June 14, 2006 QUOTE(Lars_MQ @ Jun 14 2006, 01:49 PM)Maybe you should try the fix the root of the problem smile.gif options -> directX try other decoders. smile.gif * I've tried several different audio decoders, but the problem persists. sad.gif Perhaps an error with the audiodevice driver. What kind of audiohardware are u using? mfg Steffen Quote Link to comment
KidCactus Posted June 14, 2006 Author Share Posted June 14, 2006 (edited) Perhaps an error with the audiodevice driver. What kind of audiohardware are u using? mfg Steffen <{POST_SNAPBACK}> I'm using a M-Audio Audiophile 2496 card. You might be correct, I just reinstalled my computer, but I don't think I've ever reinstalled the correct drivers for the soundcard. I'll try that. Edit: The correct drivers are installed. Edited June 14, 2006 by KidCactus Quote Link to comment
KidCactus Posted June 14, 2006 Author Share Posted June 14, 2006 I found the bad guy. It was the latency in the DVB Source Properties doing it. Quote Link to comment
