asf streaming with webserver - how?
kwunman.li@spgs.org
I finally managed to get http server working ok on W2K3 64-bit server
There are some problems, so it is not really usable at the moment in my setup.
Hope you can help me figure out how to do it
The guest account never gets created, I do not get any list of channels etc
Is there any manual for it?
Tha DVBViewer on the server is 3.2.6 & it works just fine with SkyStar2
Thanks
KL
Link to comment
Try DVBViewer 3.5 and post your support.zip.
mfg Steffen
Edited by steffenvogel
Link to comment
The guest account functionality isn't implemented yet.
OK, so how do I actually use the asf streaming?
Via webpage would be nice but with no guest account it is not possible, is it only using VLC player at the moment then?
Also it looks like the stream only is available when the this page is active http://dvbserver/stream.html?aktion=stream
Otherwise port 3335 is not active
KL
Edited by kwunman.li@spgs.org
Link to comment
