Masterpop Posted July 7, 2006 Posted July 7, 2006 Hi, I recently purchased DVBViewer Pro 3.5 Beta. I have the following BDA device: Found BDA device: WinFast DTV 1000T BDA DVB-T Tuner/Demod (Thomson DTT7579) When I start up the program, i see an error message "No Hardware Found". When I go to Settigns--> Options --> Hardware. I can see my card listed. I've tried every possible combination of settings, yet I cannot make it work... whenever the program loads it always says "No hardware found" Can anyone suggest what I migth try to get it to work? Thanks, Alex Quote
Guest Lars_MQ Posted July 7, 2006 Posted July 7, 2006 Do a channelscan. the default channellist ist SAT only. Quote
Masterpop Posted July 7, 2006 Author Posted July 7, 2006 Hi It only works if my Reception Type is "Cable". Can anyone tell me what the "symbolrates" are? Since it seems to matter in finding the channels. Does anyone else have this reception type and getting the UK freeview channels? I'm also really interested in getting the HD trials... Thank to all your replies so far. Regards, Alex Quote
Guest Lars_MQ Posted July 7, 2006 Posted July 7, 2006 Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 Quote
