gibman Posted July 30, 2006 Share Posted July 30, 2006 (edited) hi! On my server I start dvbv like this: DVBViewer.exe -c -m In other words it starts minimized and with no channel tuned. On the client I change the channel on the server by the help of the webinterface - remote control page. the channel does change fine on the server. But video and audio is being sent to the respective directshow filters, which they shouldnt, as I have "disable AV when minimized" set in options. I guess u didn't take into account the empty -c parameter, rite ? <EDIT> I did some further testing and realized that the problem is the empty -c parameter which serves the purpose to start DVBViewer with no channel tuned. The annoying workaround is to start the server with : DVBViewer.exe -c0 -m Channel 0 is tuned on server fine. Then script something like --- DVBViewer.sendcommand (12327) // untune channel. Channel 0 on server is now untuned. Now try and change channel on client web page ..viola...no DS filters on the server are fed with data. They way it should be </EDIT> /gibman Edited July 30, 2006 by gibman Quote Link to comment
