olax Posted October 31, 2006 Posted October 31, 2006 (edited) ...for me it seems like "check-box.png" and "check-boxNF.png" has been mixed up. Right now, "check-boxNF.png" is the one with the check. And another thing: I experience problems when in myVideos (also in myMusic) and try different modes; listview/small icons/large icons. For me they behave different in the aspect of moving focus to a folders/videos. When using small icons or large icons, i press left to move focus from [listview/small icons/large icons] to the files. When using listview, I can't get focus to move to the files at all. -Something strange or is it just me (or both )? /Ola Edited October 31, 2006 by olax
markymark Posted November 6, 2006 Posted November 6, 2006 Hi, very nice skin, but with two major issues for me: - navigating to the media files through cursor keys is quite annoying - the (VERY SMALL) video window seems to be positioned without accounting for the overscan settings Would be great if you find a better way for both! Anyway, keep the good work up! WBR Markymark
darky Posted May 17, 2007 Posted May 17, 2007 (edited) --> http://img177.imageshack.us/img177/6042/osdbh1.jpg 1.) Warum ist die Schrift eine andere(falsche)? Wie ändere ich diese? 2.) Zwischen der Uhrzeit und dem Namen der Sendung im EPG fehlen 1-3 Leerzeichen. Es gibt/gab dafür doch mal so ein Fix? Edited May 17, 2007 by darky
hdv Posted May 17, 2007 Posted May 17, 2007 Hallo, http://www.DVBViewer.info/forum/index.php?...ighlite=%2Bskin Da sollte eigentlich etwas dabei sein, was dir bei der Bearbeitung der OSD-Seiten weiterhilft.
darky Posted May 18, 2007 Posted May 18, 2007 (edited) hmm, wo gibts denn den fix, den ich oben angesprochen habe?? edit: hab office installiert und nun funzen sowohl schriftart als auch abstände ohne probleme! Edited May 21, 2007 by darky
avoidz Posted September 20, 2007 Posted September 20, 2007 The Default Skin is very cool; I like it a lot Is the latest default skin version 1.1 or 1.0? The Member's Area lists "New Default" as 1.1, but the skin itself (in HTPC mode) displays 1.0. The image file names for the default OSD skin in the latest DVBViewer (3.8.0.0) have dates in Dec 2006, so I assume it's the latest skin version in there. Cheers
themaster1 Posted May 7, 2008 Posted May 7, 2008 Hi, I've tried the file from 29.08. that's the only one I can find. Isn't that file right? Thank you How do you install those skins??? I have downloaded 04_blackmoon(english)1.0.zip, extracted it to finally have this file "blackmoon(english)1.0.skin"..... but then i'm lost.
IRa Posted May 7, 2008 Posted May 7, 2008 How do you install those skins???I have downloaded 04_blackmoon(english)1.0.zip, extracted it to finally have this file "blackmoon(english)1.0.skin"..... but then i'm lost. Just put that into DVBViewer/skins folder and select the skin from setting/apperance. But that is not OSD skin like default skin above
themaster1 Posted May 7, 2008 Posted May 7, 2008 and select the skin from setting/apperance. Right this is not osd skin but it's beautiful, thanks for the tip.
AEK Posted July 3, 2008 Posted July 3, 2008 The new OSD-Skin looks awesome. Some things looking ugly to me: 1) The already mentioned program-preview window in the top right corner in most of the skins is just too small. Let it grow a bit. 2) What about putting the clock into the design-concept? ;-) Maybe an analog clock will look nice in the top middle of the screen (e.g. Windows Vista-Style-like ... rrrrRRRRRR ) keep going ...
Bjur Posted December 23, 2008 Posted December 23, 2008 Where do I find this new skin in the 4.0 version? Can't find it anywhere:( Also can you use all the other OSD skins on this forum to the new version?
Moses Posted December 26, 2008 Posted December 26, 2008 Yes, there was no big changes to the osd skins.
viteok86 Posted December 9, 2009 Posted December 9, 2009 rbcarnevale Yes man ! )) This's very good interface . Hope that DVBViewer will have the same OSD and interface . Good in advance .
