Technotrend 3200 and DVBViewerGE 2.0.1.9 Beta
htpcman
Can you try this version i attached?
Yes, this version works just the same as the one I have found. Also the CAM menu entries problem is still there. Can someone confirm this?
which cams did you tried? The mmi is completely handled by the sdk and i will forward this to Technotrend :bye:
Christian
I was afraid you'd be asking this question. :bye: It's a T-Rex, I'm not expecting support for this, but was just wondering if someone with a more "regular" CAM has the same problem. If not, forget it. It's not important anyway.
Ironically, the primitive TT Media Center program that came with the S2-3200 card works fine with both my Irdeto and Nagra CAMs on all the channels I subscribe to, including HD1 at 7° East (w/ Irdeto CAM) and the three Premiere HD channels at 19.2° East (w/ Nagravision CAM).
Cheers.
Let me see if I understand you correctly:
You can watch the Premiere HD channels on your PC monitor with this DVB-S2 PCI card, right? Aren't they supposed to be HDCP protected? Did Premiere drop the protection???
Cheers.
@Threepwood
Can you advise the type/make of the Nagravision cam that you are using in your S2-3200's PC .
Thanks,
Rittberg
..Aren't they supposed to be HDCP protected?..
HDCP does diddly-squat about PC-Sat viewing.
Edited by Zyknyp
@htpcman, can you get SCPC transmissions with your multifeed arrangement? I'm interested in the symbol rate range of DVB-S1/2 demodulator on your card (STB0899 from STM).
Hi community, hi Derrick
coming back to your question. SCPC reception works fine, I've tried sucessfully to lock the HotBird 'M2' tranponder at 12.145 Ghz, Hor, with a SR of 3333 Msymbols. Do you have a more difficult scpc job for the card? I'm just receiving 13,19.2,23.5 and 28.2/28.5°E.
Oliver
Edited by linowsat
Oliver
For sure the Technotrend 3200 has a better tuner than SS2: with the former I can watch without a glitch channels whose reception isn't almost enough for a good watch with the latter (using same dish/twin LNB).
We need feedback from someone who is using the TT 3200 with DiSEqC.
Are there any problems when tuning a channel with DiSEqC other than A/A, closing DVBViewer and relaunching it? Is the last channel tuned correctly without additional measures? The retune option on the Settings -> Options -> Hardware Tab must be set to 0 for this test.
Thanks in advance ;)
I have no problem at all, i have A/A=HB, B/A=Astra28.2 ,A/B=Astra19 , it works all the time , whatever LNB is last channel.
No problem here either: A/A Hotbird 13°E - B/A Astra 19,2E° - A/B Thor 0.8W°
Retune correctly too (only thing, if it's a Favourite channel, it's diplayed as the wrong channel, that is, let's say I've got as Favourites channels "1", "2" and "3", if the last channels tuned was "2", when I relaunch DVBViewer it does tune that channel, but it's displayed in the Favourite list as "1" channel).
  • 1 month later...
This is weird, but maybe a problem caused by me. I use the Api in version 1.0.0.5 but i forgot to put it into the installer. Can you try this version i attached?
Christian
This is the wrong forum - but the proper thread ...
I have had to update the ttAPI.dll as suggested in order to get the CI-module to work with a TT C-1500 ...
I am having the same CAM menu problems - first item not shown - as reported by others.
Hardware:
Medion 8883 - 3.2GHz P4 HT - 1GB RAM
ATI Radeon 740XL Graphics
TechnoTrend Budget C-1500 Cable Receiver
Technotrend Budget PCI CI
Viaccess I/II CAM (V484)
TDCKabelTV smartcard
Software:
WinXP Home SP2 - all updates
TechnoTrend BDA Driver version 4.4.10.17
DVBViewer 3.5 PRO - DVB Source 2.8.0 and 2.8.1
Video- and audio decoders: CyberLink, Nero, and InterVideo
'ttAPI.dll' posted by 'hackbart' on Aug 19 2006, 01:26 PM
-- Erik Reeh
Cam works fine here, however it takes a while to access the CAM so decoding doesn't begin as fast the first time as on a regular STB.
  • 2 months later...
Cool for me too, whit my T3200. Its a perfect Card! But can you make the CAM faster? No 3seconds but <1 second
Edited by ErwinMeulman
