DVBViewer GE 2.0.1.10 Test and TT dvbs2
fedmond31
to Griga
some points:
i have eventually swapped my old SS2 for new DVB-S2, its working very well but i noticed:
(hardware = Pentium D805 / GF 6600 Gt video)
ON H264 (BBC HD) with the SS2 it was better with coreavc than cyberlink : more fluid for the same high cpu usage high 75/85%
with the dvb-S2 its better with cyberlink and cpu usage came down to 50/55 whereas coreavc remains at 80+
The channel list takes quite a long time to appear after request with new card/new DVBV-GE
it was almost instant with SS2/DVBV-GE 2_0_1
Finally , is there a "trick" to start DVBV-GE on no Channel/standby as opposed to last channel default ?
( i might be blind?)
Thanks again for your brillant work which made the card to work at first try !!
Have you added a lot of channels?
commandline parameter -c
thanks a lot ,definitly yes, ive made first clean install, then deleted all the preinstalled channels then did full
HB, Astra 1&2 scans.
if its slow because of too many channels, im afraid i will have to trim it down ??
DVBViewer GE uses the standard Windows treeview component, that is quite slow (will be replaced by a better one ASAP). So it is recommendable to delete all useless channels, particularly encrypted channels, resp. exclude them beforehand when performing a full scan. Nevertheless a complete Astra & Hotbird list should not cause a real annoying delay.
thanks i shall delete some and see difference.
