Joerbo Posted September 27, 2002 Posted September 27, 2002 the feature to record the second (or both) language at the same time ? There is no software on the web who can do this. DVBViewer where the first und am am shure I am not the only person who want it. Joerbo Quote
Guest hackbart Posted September 27, 2002 Posted September 27, 2002 I plan to write an additional console tool which records all files you want to have (multiplexed or demultiplexed). This will be the next step, after i finished the channel scanning routines. Christian Quote
oaks Posted September 28, 2002 Posted September 28, 2002 some channel is sending programs with AC3 audio streams. is it possible to record the AC3 stream to harddisk? no need for decoding or multiplexing it. Oaks. PS. you did a great job with the new website! ... and yes! i'll pay for your software! Quote
Guest hackbart Posted September 28, 2002 Posted September 28, 2002 well ac3 is theoretically possible and should not be such a huuge problem if b2c2 would'nt deny ac3 audio outputs. I droped them "indirectly" a line but i'm not sure if they would hear my voice. Otherwise if i finished the work on the 1.91 release, i start coding the ac3 support. Christian Quote
