Trifon Posted August 29, 2006 Posted August 29, 2006 BDA driver is recommanded when using the Twinhan 1030a. It's what I have understood from the forum. I have installed the BDA driver 1.2.3.8 Then installed MCECI so that it is launched together with Windows. My CAM Aston 1.05 is detected At that step, everything works fine excepted I have to open MCECI after each scrambled chanel change. I understand nothing is recorded under Windows XP family. Is that right? Is there some Plugin avalailable to make it automatic? Thanks for the help. Quote
Engelbert Posted August 29, 2006 Posted August 29, 2006 What is MCECI? One needs Windows 2000 (SP4) or WinXP (SP2) for the TwinHan 1030a next to the BDA drivers (WDM should go also). And the DVBViewer PRO/GE! Quote
Trifon Posted August 29, 2006 Author Posted August 29, 2006 What is MCECI? One needs Windows 2000 (SP4) or WinXP (SP2) for the TwinHan 1030a next to the BDA drivers (WDM should go also). And the DVBViewer PRO/GE! MCECIConsole.exe is needed to be launched along with Windows to watch scambled chanels. It is included in yhe 1030a BDA driver. Windows MCE allows to record scrambled chanels infos, XP not. BDA driver won't support any common interface. Regards Quote
hdv Posted August 29, 2006 Posted August 29, 2006 Hello, you using the DVBViewer Pro/GE? then post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 Quote
Engelbert Posted August 29, 2006 Posted August 29, 2006 Your TwinHan SAT CI (1030a) works with (WDM and) BDA drivers and DVBViewer PRO under Windows2000 and Windows XP, with and without MCE, if your CAM works with the TH-SW. The TH-SW isn't necessary for this. Quote
Trifon Posted August 30, 2006 Author Posted August 30, 2006 Hello, you using the DVBViewer Pro/GE? then post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 OK, hdv, I'll send all requested files to support as I use DVBViewver pro 3.5 with my 1030a Regards Quote
