manpete Posted September 7, 2006 Posted September 7, 2006 I have DVBViewer <whatever version> and I try to use it. The version I have is the thing with the full installer. I tried some GE thing but that didn't work. I also tried the beta but that also didn't work. I now have the setup.exe version again and it also doesn't work. I have a Technotrend S2-3200 card in my system which works excellent with the Technotrend software. I have a Diseqc switch with (amongst others sats) Hotbird on A/A and Astra 19.2 on A/B (no, not B/A!). When I install DVBViewer everythign seems fine. Then, while reading the manual, I perform all the other steps that the installer doesn't do. Really a tedious procedure, but what the heck... Then the program starts and it shows me the logo of some German channel. No picture. I go to the channel list, delete the channels and then perform a new scan for Hotbird. This time on switch A/A. During the scan I can see that it finds some 2000 channels or so. When the scan is finished I leave the scan windows and then I select "Save". From then on the program only crashes. I have rebooted my PC and then when I start DVBViewer it shows me the logo of "Das Erste" and then it crashes. I can not change anything or whatever, because the program only crashes and that's all. What's happening? Quote
Guest Lars_MQ Posted September 7, 2006 Posted September 7, 2006 Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 Quote
manpete Posted September 7, 2006 Author Posted September 7, 2006 Please post some more information: Attached support.zip Quote
manpete Posted September 8, 2006 Author Posted September 8, 2006 No reply? I would expect some support for this program that people can not try before they buy, no matter how cheap or expensive the price. If I can only buy a non-working program then maybe someone wants to discuss how I can get my money back (which, under current european law, is not a big problem - glad to have used Paypal...). Alternatively (the better option) someone may actually consider to explain to me why the program is not working and how I can fix it. Quote
manpete Posted September 8, 2006 Author Posted September 8, 2006 I uninstallede DVBViewer c ompletely and installed it from scratch. Once installed, I have a list of not working channels (because the Diseqc options are wrong). I selected channel editor. Then I selected Hotbird, and right-click. I set the Diseqc options to A/A and then I clicked update and save. Back into the viewer I selected an arbitrary channel on Hotbird. an image of the current broadcast (about the 9/11 towers) flashed on the screen and then DVBViewer crashed again. I restarted DVBViewer and saw a black screen. Then I selected one of the Hotbird channels again and it crashed again. It seems to me like DVBViewer crashes as soon as I start to watch a working channel. support.zip Quote
hdv Posted September 8, 2006 Posted September 8, 2006 Hello, start the DVBViewer with command "-c" like "D:\Programme\DVBViewer Pro 3.5\DVBViewer.exe" -c, so the DVBViewer don't tune a channel. now go to the Options -> DirectX and select as video decoder CyberLink Video/SP Decoder (PDVD7) and audio decoder AC3Filter. close the DVBViewer for save the settings. start DVBViewer with the normal link. what now happens. you can take a look for the DVBViewer Pro Beta 3.5.0.4, where you can find in the member area too Quote
manpete Posted September 10, 2006 Author Posted September 10, 2006 now go to the Options -> DirectX and select as video decoder CyberLink Video/SP Decoder (PDVD7) and audio decoder AC3Filter.close the DVBViewer for save the settings. start DVBViewer with the normal link. what now happens. you can take a look for the DVBViewer Pro Beta 3.5.0.4, where you can find in the member area too Yes! Now it works. By the way, when I selected the decoders I clicked on "apply" and then the program locked up. No more response. I had to stop the program using the windows taskmanager. The second time I made thje changes again and then closed the DVBViewer as suggested above. Now it works fine. Thanks for the help. By the way: Why should I use the beta? Quote
