no harware detected- cinergy t2
Magnifico
1/ I did at first launch of DVBViewer 3.5.0.1 beta:
- setting-option- hardware
and then choose device cinergy t2; try to "apply"...
then back to option channel list : impossible to scan; nothing about cinergy t2
2/ at every launch of DVBViewer, message "No hardware avaible" appears...
Note:
a/ BDA driver of cinergy t2 DVB-t : v 2.3.0.24
b/ Terratec home theater application is OK
so what ??
thx...
Use the tool TransEdit ... with his instructions (member area).
Senderscans can be made in a convenient way and sorted at own discretion with that.
One also can if necessary help the transponder files on the jumps.
thx, Engelbert TransEdit worked fine...see results in attached file.
I tried a lot of software under Xp sp2: dcdvbsource+zp,terratec home theater, MPC etc...
I wonder why Transedit (that looks like DVBViewer for device recognition) works fine and no DVBViewer. No hardware avaible.
thx for help for such a basic thing (or bug??)
mp_t2.ini
The drivers of your card are correctly registered.
Delete the hardware.xml.
Read the Readme.PDF to the PRO (members area)!
One has not leave on <auto> but adjust tightly under DirectX video and audio decoder.
At present this one recommends himself for PowerDVD 6 or 7 as a video decoder of Cyberlink (Trial suffices), as audio- and AC3-Decoder the Ac3Filter:
http://www.free-codecs.com/download/AC3_Filter.htm
Switching 'Open whole transponders' under hardware off.
The transmitter list of TransEdit shows a pawning of 167 kHz.
Freewiev in England ? Local transponder list available?
Edited by Engelbert
thx Engelbert, it works fine now, I have got all my channels here :-)
freeview in Paris not in London...
In fact, lets me explain my goal for using DVBViewer ; I used to watch my DVDs on PC with ZP+ decoder video (dscaler) + post processor video (ffdshow raw) + decoder audio (ffdshow audio -including AC3)+ audio renderer (reclock). and it is really fantastic compared to ALL other players I tried...
What I want to do now with DVBViewer, is to use video post processing (ffdshow) for TNT (MPEG2 first).
My first problem now is that I cant choose ffdshow as video decoder: it does nt appear in the list.
Second pb: I can choose ffdshow as post processor but it stops DVBViewer and I have lost sounds in my PC, i had to reinstall audio drivers!.
I have tried already 2 versions of ffdshow...I know some people here use ffdshow, I m gone ask them...maybe with graph edit and so on.
DVBViewer PRO/GE I use at the PC and for Record; Cyberlink PDVD7 (video decoder) and AC3Filter (MPEG audio + MPEG AC3 decoder, no postprocessor).. My DVDs I check also with ZP.
FFDSchow I don't hardly know and need it. Sorry.
