Sky UK EPG
Whitey
Can DVBViewer be setup to use Sky UKs full 7-day epg?
At the moment I only get the now and next information for channels in transponders that I have tuned into.
AIUI Sky UK uses a MHW type epg broadcast on the default transponder.
Thanks
Whitey
  • 3 months later...
I know its a bit of an old post but where you able to get the full 7 day sky EPG wokring for the UK and if so how?
I'm baffled by the cryptic replies also, perhaps an explanation would be more helpful!
I use the "MyXMLTV" plugin to convert an XMLTV file that I download from the radiotimes to use with DVBViewer. With this you get most of the more popular channels
Whitey
  • 7 years later...
Whitey
Sorry to bump a very old thread, but I'm thinking of buying / installing DVBViewer, but I want to be sure that it will be able to provide a 7 or 14 day EPG for the Sky UK encrypted channels such as Sky Sports etc.
Is someone able to confirm that it is possible to get a Sky UK EPG in DVBViewer?
Also, you are able to do this, what app do most people use to do this? (I did a search for "MyXMLTV" and couldn't find much up-to-date information on it.
Thanks in advance for any replies.
bb69
wg++ for example:
http://www.webgrabplus.com/
DVBViewer cannot natively get the Sky EPG, but it can get the Freesat EPG. To get the Sky EPG you need to use a seperate program that either gets it from the web or from satellite and them imports it into the Recording Service. In some cases you need to use two programmes - one to gather the dat and one to import the data. Most people use a timer in recording service to launch the EPG grabber so that once it is configured, you never have to think about it again.
I use EPG Collector. It grabs the EPG from satellite and automatically devliers it to the Recording Service. I personally find it the easiest to use.
C.
