Lebeck Posted September 30, 2006 Share Posted September 30, 2006 Hi, I have problems viewing "Viasat TV3" using DVBViewer... when the channel is selected in the "Channel list" the screen goes blank, but EPG info is displayed. No audio aswell. The channel is found automatically when scanning for channels. I have heard from a few other guys in a danish forum that they experience the exact same problem with DVBViewer. I do not know their HW setup. I have no problems viewing "Viasat TV3" in other programs like MyTheatre and MediaPortal. See the settings in the attached file. Software: Windows XP SP2 - English version - with all updates from "windowsupdate.microsoft.com" DVBViewer 3.5.0 PRO Nvidia Driver 92.91 Hardware: Dell Optiplex GX280 SFF 2,8 GHz P4 512 MB RAM XFX GeForce 7300LE FireDTV-C TV Tuner - BDA Driver Version: 4.2 - Firmware: 1.2.1 Quote Link to comment
Derrick Posted September 30, 2006 Share Posted September 30, 2006 dunno what's wrong. Is it 256-QAM ? There is an issue with high rate multiplexes. The firedtv-interface can't cope with such high rates. But there should be a workaround using hardware pid_filters. None of the developers has danish cable. Please add the usual support.zip to exclude directshow problems. Some of the scandinavian channels use rather low resolutions. What does the DVBViewer filter say? Quote Link to comment
Lebeck Posted September 30, 2006 Author Share Posted September 30, 2006 (edited) dunno what's wrong. Is it 256-QAM ? There is an issue with high rate multiplexes. The firedtv-interface can't cope with such high rates. But there should be a workaround using hardware pid_filters. None of the developers has danish cable. Please add the usual support.zip to exclude directshow problems. Some of the scandinavian channels use rather low resolutions. What does the DVBViewer filter say? It is QAM-64 ... (but actually QAM-256 is supported in the latest FireDTV firmware)... I will add the support.zip later this evening. Edited September 30, 2006 by Lebeck Quote Link to comment
hdv Posted September 30, 2006 Share Posted September 30, 2006 Hello, FireDTV-C TV Tuner - BDA Driver Version: 4.2 - Firmware: 1.2.1it gives a newer firmware for the DVB-C FireDTV, now its 1.2.2 digital-everywhere.com look Quote Link to comment
reeh Posted September 30, 2006 Share Posted September 30, 2006 ... I have problems viewing "Viasat TV3" using DVBViewer... when the channel is selected in the "Channel list" the screen goes blank, but EPG info is displayed. No audio aswell. The channel is found automatically when scanning for channels. I have heard from a few other guys in a danish forum that they experience the exact same problem with DVBViewer. I do not know their HW setup. I have no problems viewing "Viasat TV3" in other programs like MyTheatre and MediaPortal. ... I just see that Lebeck has posted the same problem as I have, while I was investigating and editing my posting ... I have much additional diagnostics information in my posting: "TV3 on Danish TDCkabelTV Cable Network" -- Erik Reeh Quote Link to comment
reeh Posted October 1, 2006 Share Posted October 1, 2006 Hi 'Lebeck' As you can see in the thread 'TV3 on Danish TDCkabelTV Cable Network', the problem is being worked ... The question came up, whether you have the proper CI/CAM equipment - decryption hardware including a TDCkabelTV smart card ? Quote Link to comment
