Kaloschke Posted October 7, 2006 Share Posted October 7, 2006 Hi, perhaps I'm to stupid, but I can't set a PID in the Alphacrypt menu, when I want to update my modul. Within the menu I reach a number-array and I can use the mouse or the keyboard, but nothing happens. Maybe it's a bug? Or is there something, that I can do? Greetings Kaloschke Quote Link to comment
Guest Lars_MQ Posted October 7, 2006 Share Posted October 7, 2006 Well since we don't know which dvbcard you use, we can't help you. CI handling is different for each DVB-Card. BTW I took the liberty to correct the topic, so nobody mistakes it for badly spelled french Quote Link to comment
Kaloschke Posted October 8, 2006 Author Share Posted October 8, 2006 Hi, I use the Twinhan Sat CI. I didn't talk about that, because I thought, the OSD-menu has nothing to do with the hardware. BTW I took the liberty to correct the topic, so nobody mistakes it for badly spelled french Thank you very much Greetings Kaloschke Quote Link to comment
