gerilla Posted October 10, 2006 Posted October 10, 2006 hi; my friend uses DVBViewer with his ss2 card and he can watch hdtvs clearly. and i want to buy DVBViewer too. but when we plug my card to his computer for test, the DVBViewer cant see my inca dvb-s card. i install latest drivers but no change. there isnt my card in hardware list. what is the problem??? please help me? i wanna buy a software supported with my card... Quote
hdv Posted October 10, 2006 Posted October 10, 2006 Hello, DVBViewer cant see my inca dvb-s card. i install latest drivers but no change.have you installed BDA (MCE) driver? TechniSat and Twinhan cards working with own driver all other devices must have bda driver Quote
gerilla Posted October 10, 2006 Author Posted October 10, 2006 where i can download bda drivers? Quote
hdv Posted October 10, 2006 Posted October 10, 2006 Hello, on the website from card manufacturer if it dont give bda driver you can't use DVBViewer with your card BDA Wikipedia Quote
gerilla Posted October 10, 2006 Author Posted October 10, 2006 Hello, on the website from card manufacturer if it dont give bda driver you can't use DVBViewer with your card BDA Wikipedia we installed it from twinhan website but no chance. we are at computer since this morning.we will go crazyyyy... please help? what is the matter Quote
Gioxy Posted October 11, 2006 Posted October 11, 2006 Without more info we can't reply... Always follow these instructions. Otherwise no one can - or wants - to help you! Quote
Derrick Posted October 11, 2006 Posted October 11, 2006 Without more info we can't reply... Always follow these instructions. Otherwise no one can - or wants - to help you! A new member in the choir? Only 4. could apply: 4. If nothing applies you should use the search function of the DVBViewer-forum. Select Search, enter a search item (at least 4 letters), and pay attention to the search options. Make several attempts with different terms; there is a high probability that it is not a new problem and that there's already a solution for it. inca ist a 4 letter word. Performing a search only leads to this thread The DVBViewer is called an *egglayingwoolmilkpig* but sawing is not a feature yet. Maybe in the future ? Quote
gerilla Posted October 11, 2006 Author Posted October 11, 2006 system : amd athlon 1700 1.5 GB DDR 160 GB HDD 256 MB Ati Radeon 9600XT INCA DVB-S i added setup.xml to attachments. (there isnt any log file) setup.zip Quote
