Streaming
owngoal
Could someone help on streaming.
I have DVBViewer V3.5.0 running successfully on two PCs on my wired home network. I am using a AVerMedia PC Cardbus Video Card.
Next step was to get the streaming to work between the two PCs - as I only have 1 Video card.
Setup seems ok - I've been following the help file and also posts to this board.
The server starts ok on Unicast and recognises and displays the client correctly.
On the client I use the autodiscover to make the settings and everthing looks to be ok.
I can change channels and the OSD works displaying the correct program information.
The only problem is that there are no audio-visuals - it is clear that the two PCs are commnicating together just no sound or picture.
Any ideas ? - the streaming concept is a fantastic prospect on what is already a great piece of software.
GL
Thanks for the suggestion but I've already read this topic and tried what was suggested.
It may be a CODEC issue. You need to have an MPEG2 decoder installed on the clients. Check what DirectShow filters you are using with View->Filter Graph
