DVB-C CAM for UK NTL Cable
Creagan
Hi there,
I would like to ask if anyone tried using the "TwinhanDTV Cab-CI" DVB card with ntl cable television in the UK?
I am panning to use my PAID for/ LEGAL smart card and the above card to watch television, but I am not sure which CAM will work with DVBViewer.
I am thinking of useing the following:
-DVBViewer
-TwinhanDTV Cab-CI
-CAM which is campatible with DVBViewer
-PAID for NTL cable smart card
If anyone could confirm a compatable CAM that will work with DVBViewer, or any problems that I might run into, it would be great!
Thanks...
I believe that NTL use Nagravision & that your card is married to a particular decoder box. In theory a Dragon/T.Rex CAM should work with predator firmware that allows you to enter the serial number of your box into the CAM.
I bought the new T Rex 4.6 CAM and a Technotrend Budget C 1500 cable card, but when I start DVBViewer, the application reports that there is no supported hardware.
I looked at the supported devices list before I could the technotrend card, but is does not seem to work - do you know how to get it working with DVBViewer, or should I just bin the card.
I know you should install DBA drivers - how do you KNOW they are installed?
Thanks for your help... appreciated!
I checked the driver versions and they are the latest.
Thanks for your help!
I will post on the forum mentioned above.
Thanks
