Powerdvd decoder
cockers
Hi there,
I have had problems with the previous build (stuttering on h264) so I thought I would install what I think is the latest. It's a great improvement - no stuttering at all.
I couldn't get it from the Cyberlink website, but free-codecs have a link.
For info, I am running this on a Mac mini core duo, with DVBViewer 3.5.
Hi!
Which card do you use? TT S2-3200?
Do you mean the PDVD 7 trial to download? Is the trial like an update when you use a full version already? Is it really the h.264 version?
Thanx!
Markus
I think it's trhe same version that it's installed with the driver CD of TT-3200 cards...
I don't know which PDVD version I did installed with the TT S2-3200 installation CD. When I start PDVD it only shows that it's the 7.0, even when I use the "info" button.
If you want to find out what version you have installed...
1. Select the 'PowerDVD' shortcut on the desktop.
2. Right-Click and select 'Properties'.
3. Click the 'Find Target' button.
A new window will open. The Powerdvd exe will be highlighted.
4. Right-Click the PowerDVD exe and select 'Properties'
5. Click the 'Version' tab.
You will see which version you have installed.
WOW, thnk you for the info, now I found out which version is on my TT-CD and also installed on my system, it's the one you have linked to. I have stuttering while watching even it's installed. :)
I have an AMD 64 3500+, it's the min. CPU you should have to watch h.264, I think I will look out for a new one these days, maybe an X2 CPU with a little more speed.
On my system CoreAVC is stuttering more then Power DVD.
Ditto. With Cyberlink I can watch a few H.264 channels (German FTA ones, Luxe TV) fine, with CoreAVC no way.
Edited by Zyknyp
Should be the newest, I bought it some days ago. It's CoreAVC 1.1.0.5.
Yesterday I downloaded the new DVBViewer Filter 2.8.2 (PushSource), it reduced the stuttering much! :)
