How to setup EPG
Lebeck
Can anyone direct me to a guide to setup EPG in DVBViewer?
I'm only gettings now and next show in the EPG window.
Guest Lars_MQ
Do you use a recent channellist (recent= not from the DVBViewer TE or from older (>3.2.5) DVBViewer Pro)? if not, please try a update channelscan.
Also note that some providers only provide the now and next epg. Maybe you state which channels you use and other users (who do receive the same channels) say something about it. :bounce:
Also note that some providers only provide the now and next epg. Maybe you state which channels you use and other users (who do receive the same channels) say something about it. :)
I have a completely new channel list... and all channels show only "Now and Next" show.
Here are a few of the channels:
Discovery
CNN
EuroSport
Disney Channel
Animal Planet
RTL
Pro7
SAT1
BBC Prime
BBC World
I'm running DVDViewer Pro 3.5.0.50
Guest Lars_MQ
And you're using DVB-C (if I remember correctly) and have which cable provider?
I'm using the FireDTV-C TV tuner on TDC Cable TV.
The strange thing is that I in connection with resolving my "No Audio/No Video" issue after installing beta versions - I installed my TV-tuner and DVBViewer on my other PC and it seems to work here??? Why is that?
I have disconnected the TV tuner from my other PC again but EPG still works on the few channels I watched using this PC... there is no EPG info on any other channels. Is that because I did not tune in to any of them while the tuner was connected?
Is there anything I can reset to make EPG work again on my media PC?
Edited by Lebeck
Guest Lars_MQ
Please delete the epg.dat in your DVBViewer folder. it gets recreated. If this doesn't work, please use the supporttool and post a support.zip. :)
I have tried deleting epg.dat but it did not help - unfortunately :)
Support.zip attached.
Edited by Lebeck
