Kevin Steggles Posted October 24, 2006 Posted October 24, 2006 I've recently been suffering from jerky video and the number of discontinuities (whatever they are). I've reloaded everything, checked my PC for everything, tried different pci slots for my Skystar 2....you know, all the obvious stuff (including checking the forum!) Any idea why this might have started happening? support.zip Quote
Griga Posted October 24, 2006 Posted October 24, 2006 number of discontinuities (whatever they are). Missing data packets, mostly due to bad signal / reception /weather conditions. What does DVBViewer display as signal quality (see status bar)?. Quote
Kevin Steggles Posted October 24, 2006 Author Posted October 24, 2006 (edited) Thanks Griga. The reception should be as strong as ever as nothing's moved, and the same dish connects to two Sky Digiboxes which work fine. According to setup4pc, the signal strength is a steady 70% and the SNR is around 10.0. The DVB status bar says 720 x 576 25fps 256kbps 48.0kHz and between 2.7 - 5.0MBit (fluctuates) Edited October 24, 2006 by Kevin Steggles Quote
Griga Posted October 25, 2006 Posted October 25, 2006 Are the discontinuities still there? How often does it occur? All the time, summing up to hundreds, or only 1 or 2 every now and then? See View -> Filters -> DVBSource... Quote
Kevin Steggles Posted October 25, 2006 Author Posted October 25, 2006 It doesn't seem to be happening this morning (yet) but when it did, the discontinuities would run into the hundreds and happen pretty consistently. I've tried all sorts of decoder combinations, but nothing made any difference. I rarely turn my computer off, but I did last night, so perhaps it's an overheating issue? I'll monitor things today. Quote
Guest Lars_MQ Posted October 25, 2006 Posted October 25, 2006 My guess it's overheating. does the signal display in the DVBViewer statusbar start to dance cha cha cha? Quote
Kevin Steggles Posted October 26, 2006 Author Posted October 26, 2006 More of a Rumba I'd say. It seems to have sorted itself now, I've pointed a fan towards the card, and it seems to be fine, so I guess it was a heating issue. Thanks Quote
