TomH Posted November 4, 2006 Posted November 4, 2006 Hi. I have just installed DVBserver on a "master-PC" and DVBViewer as a client on a HTPC. It's working OK except with crypt/coded channels. I have selected "has CI module" on the client but when I select a crypt channel I get a CI-Viacess dialog with message "has no right" on the server. Why? If I run DVBViewer on the master-PC I get all channels to work fine, also crypt channels. I have a FireDTV and Boxer (DVB-T in Sweden). Please help! Quote
Derrick Posted November 4, 2006 Posted November 4, 2006 can't help you but I moved it cos I also think that it could be bug Quote
Guest Lars_MQ Posted November 4, 2006 Posted November 4, 2006 I don't think it's a bug. There are far to few informations to even consider it a problem. Quote
Derrick Posted November 4, 2006 Posted November 4, 2006 ..the mandatory support.zip won't help much in these cases. Though I don't say it's not useful at all May I remind you, that the channel_switching_bug in the_same mux is still not solved, at least not in the current beta of the member`s area Quote
TomH Posted November 4, 2006 Author Posted November 4, 2006 (edited) Derrik - thanks! Lars_MQ -I have now checked all channels and some coded channels is working and others are not. Well I try to add more info. Please ask if I have missed something important: DVBServer 3.5.9.1 (beta) Settings ..Network ....Server ......Streamtype=Unicast, port=4012 ....Unicast ......Interface=192.168.0.120 ......Max users=1 ......Port=2345 ......Buffercount=348 ......Max buffer=5 ....Autodiscovery=not selected DVBViewer 3.5.0.1 (beta) Hardware ..Unicast Network Device ..Tuner type=Terrestrial ..State=Preferred (all others do not use) ..Has CI module=selected (all others not selected) Network Settings ..DVBServer ....Address=192.168.0.120 ....Port=4012 ..DVB Unicast ....Interface=192.168.155 ....Address=192.168.0.120 ....Port=2345 Edited November 4, 2006 by TomH Quote
Derrick Posted November 4, 2006 Posted November 4, 2006 ..add the support.zip ! It contains all the network stuff and settings. But there is no problem cos FTA channels are ok. CI is still buggy and to get support from the devs is sometimes not easy.. Quote
hdv Posted November 4, 2006 Posted November 4, 2006 Hello, Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 Quote
TomH Posted November 5, 2006 Author Posted November 5, 2006 (edited) OK. Master PC (server) = support_1.zip HTPC (client) = ... no space for this zip? How to do now? Edited November 5, 2006 by TomH Quote
Derrick Posted November 5, 2006 Posted November 5, 2006 Your beta is a little outdated. You should always try the latest versions of DVBViewer and server from the members area. Quote
TomH Posted November 5, 2006 Author Posted November 5, 2006 Your beta is a little outdated. You should always try the latest versions of DVBViewer and server from the members area. Now I don't understand. I have version 3.5.0.1 of the DVBViewer and on the download area I can only find : » Description: DVBViewer ( 82322 Downloads ) » Version: V3.5.0 » Size: 6378 KBytes » Last Updated: 18.06.06 I made a new down load again and install it, but still 3.5.0.1. (?) And the DVBServer is older on the down load area. I have 3.5.0.1 : » Description: DVBServer ( 5848 Downloads ) » Version: 3.2.5.51 » Size: 279 KBytes » Last Updated: 14.02.06 (Not down loaded) Please have patience with me, this is all new to me. What beta are you referring to? Quote
TomH Posted November 5, 2006 Author Posted November 5, 2006 I don't compute. What file/s should I download and install? Where can I find these file/s? I have only installed DVBViewer and DVBServer (as faar as I know) and these are the latest ones. Quote
Derrick Posted November 5, 2006 Posted November 5, 2006 How did you manage to get the beta version that you use ? System:------- DVBViewer Version: 3.5.0.1 (beta) DVBSource Path: C:\Program\DVBViewer\Filters\PushSource.ax DVBSource Version: 2.8.0.0 ..you have to scroll down a little in the member's area: Quote
TomH Posted November 5, 2006 Author Posted November 5, 2006 (edited) Allright. Now I have downloaded the new beta : » Description: DVBViewer ( 1652 Downloads ) » Version: 3.5.0.50 » Size: 2162 KBytes » Last Updated: 22.10.06 Unzipped and copy with replace to the DVBViewer folder for both server and client PC:s. No other changes are made. It's working as before. - All uncoded channels working well. - 3 coded channels is working without problem - Discovery channel I get Donald Duck sound but no picture. - Rest of the coded channels is not working at all. Should I make a new support-zip file? But how to upload in that case (no space). Edit: Just found out that if I select a uncoded channel before I select a coded channel most of the coded channels are working, but not all. If I select 2 coded channels after each other I only get 3 coded channels to work. Edit 2: Actually I can get all coded channels to work by selecting a uncoded channel before. But it takes about 15 sec to change to a coded channel and only 1-2 sec for switching between uncoded channels. I think a have located the problem but how to solve it? Edited November 5, 2006 by TomH Quote
Derrick Posted November 5, 2006 Posted November 5, 2006 yes, a new support.zip could be helpful. If you don't have space, just edit your previous post and delete the attachement. Also make a fresh channel scan. Quote
hdv Posted November 5, 2006 Posted November 5, 2006 Hello, But how to upload in that case (no space).go on top (here in the forum) to My Control -> Manage Your Attachments, there you can delete your other attachments Discovery channel I get Donald Duck sound but no picture.use the AC3 Filterunder Options -> DirectX select the AC3 Filter for MPEG Audio and MPEG AC3 Quote
TomH Posted November 5, 2006 Author Posted November 5, 2006 (edited) Shit. I didn't realise that there was a new page... Copy: Actually I can get all coded channels to work by selecting a uncoded channel before. But it takes about 15 sec to change to a coded channel and only 1-2 sec for switching between uncoded channels. I think a have located the problem but how to solve it? HDV: Thanks! support__server.zip support_client.zip I changed to Cyberllink audio codec and as you wrote and it's working! Edited November 5, 2006 by TomH Quote
Derrick Posted November 5, 2006 Posted November 5, 2006 Are the channels in question in the same mux (same frequency) ? If yes, it could be related to this bug which is still not fixed ! Quote
TomH Posted November 5, 2006 Author Posted November 5, 2006 (edited) OK. It's probably the same bug. I can switch between coded channels as far as they are on different MUX. Edited November 5, 2006 by TomH Quote
Derrick Posted November 5, 2006 Posted November 5, 2006 I don't think I can help you any further.. ..though I'm interested in the dvb-aspects . Could you analyze the muxes with transedit and store the result as xml ? Make sure that you uncheck EIT in the analyzer part of transedit's settings. Otherwis the file will be too big for an attachement. Quote
TomH Posted November 5, 2006 Author Posted November 5, 2006 (edited) Hope I got it right... Sweden_TomH_754000.xml Do you want all muxes? Edited November 5, 2006 by TomH Quote
Derrick Posted November 6, 2006 Posted November 6, 2006 Do you want all muxes? no thx, the one is enough for me. I can't see anything special in the SI and the viaccess ca_descriptors in particular. Quote
