espeneppi Posted November 10, 2006 Share Posted November 10, 2006 I have a technotrend s2-3200 + CI card. But i cant get the CI part to work with DVBViewer, just a black screen. The CI works fine with TT media center. Someone who can help me? Quote Link to comment
hdv Posted November 10, 2006 Share Posted November 10, 2006 Hello, Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 And use the newest DVBViewer Pro Beta, can find in the Member-Area -> Beta Section. Quote Link to comment
espeneppi Posted November 11, 2006 Author Share Posted November 11, 2006 (edited) ok, im attaching setup.xml and support.zip now. The supporttool did not work in the beta version, so this are the files from the 3.5.0.1 Setup.xml support.zip Edited November 11, 2006 by espeneppi Quote Link to comment
espeneppi Posted November 11, 2006 Author Share Posted November 11, 2006 (edited) I have fixed the problem, i found a ttAPI.dll file that was posted in the forum, and now it works. Edited November 11, 2006 by espeneppi Quote Link to comment
politby Posted December 5, 2006 Share Posted December 5, 2006 I have fixed the problem, i found a ttAPI.dll file that was posted in the forum, and now it works. I'm also having some problems with this - the CI sometimes works, sometimes not - very flaky and unpredictable. Is your configuiration stable now - can you point me to this .dll? /POL Quote Link to comment
yaRincewind Posted December 5, 2006 Share Posted December 5, 2006 Had the same Problem, with the 3.5.201 Beta (?) (the latest) I think it works stable, but need some more testing... Quote Link to comment
politby Posted December 6, 2006 Share Posted December 6, 2006 Had the same Problem, with the 3.5.201 Beta (?) (the latest) I think it works stable, but need some more testing... Okay, I installed the ttapi.dll file from the Technotrend package and now it works better; the channels are tuned in alright and the CAM works. But I have two remaining problems: - Sometimes after watching an H.264 channel for a while DVBvewer hangs the entire system Hard reset needed... - I still get a jittery picture and sometimes bad audio sync. CPU load is below 50% (I have a Core 2 Duo CPU) so CPU performance should not be the issue. /POL Quote Link to comment
fuseblower Posted December 15, 2006 Share Posted December 15, 2006 Okay, I installed the ttapi.dll file from the Technotrend package and now it works better; the channels are tuned in alright and the CAM works. But I have two remaining problems:- Sometimes after watching an H.264 channel for a while DVBvewer hangs the entire system Hard reset needed... - I still get a jittery picture and sometimes bad audio sync. CPU load is below 50% (I have a Core 2 Duo CPU) so CPU performance should not be the issue. /POL Can anyone tell me where ttapi should be placed. Is it not already in windows following installation of the technotrend drivers? Any advice appreciated. Thankyou Quote Link to comment
