Klaus_1250 Posted November 11, 2006 Posted November 11, 2006 Whenever I switch to an encrypted channel, which is not broadcasting, DVBViewer crashes my Alphacrypt (reboot neccessary to get it up again). I can still watch FTA-channels, but none of the encrypted channels work anymore and the CAM gives an error when trying to access it. I tested this on purpose, since many STB's exhibit similiar behaviour. They either crash on non-broadcasting channels, or crash when a channel stops broadcasting (and the only solution is a reboot). I'm not to keen on DVB yet, but from the various topics I've read, it has to do with SDT, PMT's and MPEG-stills Quote
Guest Lars_MQ Posted November 11, 2006 Posted November 11, 2006 Well why a bug report for the DVBViewer? obviously it's CAM (Hardware) related. The DVBViewer does nothing out of the ordinary and if the CAM can't handle a "empty" channel, what are we supposed to do? Quote
Derrick Posted November 11, 2006 Posted November 11, 2006 @Klaus, for a better understanding of what is the reason for this behaviour, you could use transedit's analyzer, save the mux data as xml (deactivate EIT in transedit's setting) and post this file with an indication of an "empty channel". Quote
Klaus_1250 Posted November 13, 2006 Author Posted November 13, 2006 save the mux data as xml Stupid question, but... how do I do that exactly? Analyze the frequency, slecect the transponder and than Save as XML? @lars: the reason is, that both TwinhanDTV and myTheatre show different behaviour. Quote
Derrick Posted November 13, 2006 Posted November 13, 2006 select -> Analyze -> Transponder -> Save as XML (EIT deactivated in the settings cos otherwise the file gets too big) Quote
