Cutting Recording Files, Playlist stopping
alexk61
1. I've found, that DVBViewer (currently 3.5.01) makes incorrect cutting of the recording files, if file size is set higher than 4 Gb. Sizes up to 4 Gb are cutted exatly as set, but higher values results incorrect sizes (instead of 4480 Mb I have something like 4755). Setting lower values results some times other side incorrection - instead 4300 I have some 4100 Mb. The problem for sure presents on HD channels, Standard channels I didn't test.
2. Playlist works fine with the recordings from standard chnnels, but with HD channels recordings stoppes itself at the end of the first file in the list, to start next file I should doubleclick it. (tried with scrambled and FTA channels with the same result).
