XVR-renderer?
damjang
How is the progress of coding of the XVR-renderer? Are the compatibility bugs gone or is still in progress? :rolleyes:
damjang
Guest DAvenger
It is necessary to rewrite it once again to make it a little bit more faster and more COMPATIBLE :rolleyes:
OK! Thanks... I can only wish good work :rolleyes:
damjang
Yes, I would like to see an enhanced version too.
The current release of the XVR Renderer shows one major advantage: On my Computer (WinXP, GForce MX440) it displays TV much smoother than the M$ overlay mixer/ video renderer.
But there are still some drawbacks:
- It doesn't work with Marfis Renderer
- Sometimes parts of the picture appear horizontally misaligned for a short moment, particularly in "full motion" sequences (when the camera is moving from left to right, for example)
- Sometimes switching to full screen mode doesn't work correctly: The screen gets black, but the unresized picture only occupies the upper left quarter. After switching to a channel with a different resolution it usually works again.
- XVR easily gets "out of tune" after fast channel switching.
Without these drawbacks XVR really would be a great thing... and I really would like to give that overlay mixer a final kick. So I hope that Igor will polish it up soon...
Griga
Guest DAvenger
XVR works fine with Marfi's Source for me :huh: I am not 100% sure though. :rolleyes:
Hm, I checked it again... you're right, it does, but only with the Mediamatics decoder, I had it unregistered for some time. Here are the results in detail:
Marfi's Renderer -> Mediamatics -> XVR: OK
Marfi's Renderer -> Elecard -> XVR: Black Screen
Marfi's Renderer -> InterVideo -> XVR: Only artistic artefacts, very nice :rolleyes:
Marfi's Renderer -> Mediamatics -> Overlay Mixer: OK
Marfi's Renderer -> Elecard -> Overlay Mixer: OK, but 480x576 resolution not displayed correctly as 4:3
Marfi's Renderer -> Intervideo -> Overlay Mixer: OK
SkyStar 4.2 -> Mediamatics -> XVR/Overlay Mixer: OK
SkyStar 4.2 -> Elecard -> XVR/Overlay Mixer: OK, additionally needs FFDShow for correct 480x576 display
SkyStar 4.2 -> InterVideo -> XVR/Overlay Mixer: Doesn't work in both cases
I suspect that the "upper left corner" problem is a bug in DVBViewer and/or Marfi's Source filter
May be... but oviously not in Marfi's Filter, because it happens with the SkyStar 4.2 source as well. Christian should check this... I will try to find out under which circumstances it occurs, so I can send him a clear bug report.
Griga
i can confirm Grigas analysis
Guest DAvenger
I hope Igor finds some time to come here and explain the incompatibility issues a bit. Also, he might be able to answer the WHEN questions :rolleyes:
I tried to check that "XVR upper left corner bug" again, but now, as I want to get it, it won't occur again... (*sigh*) that's how it always goes :)
The fast channel switching problem definitely occurs when the resolution is changing, for example from 720x576 to 704x576.... resulting in very nice color patterns on the screen :) It looks like the XVR needs a rebuilt graph to change to a different resolution without problems.
Griga
Guest Michael
Griga
XVR won't work on X-Zone at all :( and some others....
Guest Oliver
Right so! Together against obscenity! :)
Bye, Oliver
