bmbsa Posted December 6, 2006 Share Posted December 6, 2006 (edited) Hi there, I have a satellite card from technisat (Sky Star 2).. I beleive that DVBViewer TE doesn't have the feature of recording multiple channels but it's available for other versions as listed on the website (recording of multiple channels mediafiles in the same time). Would I be able to record two different channels simultaneously into two different files using one card (technisat) if I purchased the version that supports this feature? Thanks Edited December 6, 2006 by bmbsa Quote Link to comment
hackbart Posted December 6, 2006 Share Posted December 6, 2006 You are right this is a feature of the pro (and ge) version only and it is not implemented in the free te. Christian Quote Link to comment
bmbsa Posted December 6, 2006 Author Share Posted December 6, 2006 ok.. - How many channels can I capture using one PCI card? - Is the pro version compatabile with my card (Technisat Sky Star 2) Thanks Quote Link to comment
Engelbert Posted December 6, 2006 Share Posted December 6, 2006 Ten or more channels with SkyStar and PRO/GE. Quote Link to comment
admi-ral Posted December 6, 2006 Share Posted December 6, 2006 Ten or more channels with SkyStar and PRO/GE. if they are on the same transponder Quote Link to comment
bmbsa Posted December 6, 2006 Author Share Posted December 6, 2006 Ten or more channels with SkyStar and PRO/GE. Wow... I just need to capture 2 or 3 different channels at the same time. Is SkyStar the best satellite card? Which satellite card can best handle the process of video capturing ? Thank you Quote Link to comment
Griga Posted December 6, 2006 Share Posted December 6, 2006 I just need to capture 2 or 3 different channels If they are located on different transponders (frequencies) you will need two or three DVB tuners. A single DVB card can receive only one frequency at a time, but mostly the broadcasted data stream contains several channels. Is SkyStar the best satellite card? The SkyStar2 is a good and reliable card. However, it is always a kind of gamble, because nobody is able to predict how card X will behave in an unknown PC Y. You will have to try. Which satellite card can best handle the process of video capturing ? If the card works well, capturing (recording) is more a software thing, not hardware. Quote Link to comment
Kadiac Posted December 6, 2006 Share Posted December 6, 2006 If they are located on different transponders (frequencies) you will need two or three DVB tuners. A single DVB card can receive only one frequency at a time, but mostly the broadcasted data stream contains several channels. The SkyStar2 is a good and reliable card. However, it is always a kind of gamble, because nobody is able to predict how card X will behave in an unknown PC Y. You will have to try. If the card works well, capturing (recording) is more a software thing, not hardware. Hi guys.... Sorry I myself have a SS2 pci card ... I cant seem to get going.... Ive tried to scan channel but never finishes the sat it starts to scan...... I followed the Manual to a teeth.... the only thing That I did not do is regestering the .ax file .... after creating the subfolder called ... Regfilter... I ve tried to open this ... Radlight Filtermanager ... to register the .ax files ... I could not it says that I have to login... wel the DVBViewer I m using now is the TE version..... not the pro... I understoud that I dont neeed to register to start using this card..... Any one of you guys has some input in this please let me Know Thnaks Quote Link to comment
Engelbert Posted December 7, 2006 Share Posted December 7, 2006 Oha, not TE-Version, only PRO/GE from here, 15 € Lizenz. Quote Link to comment
