Klaus_1250 Posted December 10, 2006 Posted December 10, 2006 As the topic title says. When open the Settings menu or right clicking in the picture, there is a menu-item Subtitel where you optionally select Subtitles. It should be spelled as Subtitle instead of Subtitel. Quote
Guest Lars_MQ Posted December 10, 2006 Posted December 10, 2006 Fixed it. Some german sneaked into the english.lng. Quote
Benarty Posted December 10, 2006 Posted December 10, 2006 You can use the language editor to change the language also. Quote
Guest Lars_MQ Posted December 10, 2006 Posted December 10, 2006 Well in fact you can use every text editor to change it. The language editor is more for translations and a little overkill for 2 search and replace actions. Quote
