DVB-T Freecom (BDA) not playing sound
Vulty
After finding the new Freecom BDA drivers I have swapped to using the DVBViewer software. I have installed after removing the old WDM , and the stick is recognised, channels scan (found 90 channels) and I get fine picture, but no sound.
If I change the setting to detect audio format, I lose picture as well (tho epg etc still works fine) and cant get it back again without re-installing.
Is there something Im doing wrong , or can someone point me to better BDA drivers for the stick ?
A part to find better BDA driver, try to impose this settings in "Settings / Options / DirectX":
Audio Renderer = "Direct DirectSound Device"
MPEG2 Video Decoder = "Cyberlink Video/SP Decoder"
MPEG Audio Decoder = "AC3Filter"
MPEG AC3 Decoder = "AC3Filter"
"No" Audio Format Detection
"No" Video Format Detection
"Yes" Use AudioFilter for visual and Equalizer
...and let us know...
>_<
Edited by Gioxy
