blomman Posted December 21, 2006 Share Posted December 21, 2006 Congrats to an exellent program, best/most stable tv software i ever used. Currently running latest beta version v3.5.0.121 using a FireDTV-S satbox with a conax cam. Have some questions i didn't find answers for: 1) Teletext Subtitles sometimes don't start on channel change, after reselecting in subtitle menu it comes back, is it a bug ? 2) Channels with multilanguage stereo sound like cartoon network, must manually change to left speaker in balance everytime when watched. Tried the RLAudioSel plugin but it broken AC3. Would be nice if that could be fixed in channel editor and option to upmix left channel to stereo.. 3) OSD Teletext, option to have a fixed 4:3 aspect ratio. L.o.o.k.s...l.i.k.e..t.h.i.s..n.o.w.=.h.a.r.d..t.o..r.e.a.d Tried different fonts but none makes it readable... 4) More Zoom options, -like MCE's intelligent zoom -Option not to zoom on 16:9 source 5) Even faster channel changes if possible, or is that a hardware/driver limit ? 6) For nordic canal digital channels the EPG info is in danish/norwegian language. Can you change to swedish somewhere ? Gets swedish language when using my old satbox. Thank you Quote Link to comment
cango Posted December 21, 2006 Share Posted December 21, 2006 6) For nordic canal digital channels the EPG info is in danish/norwegian language. Can you change to swedish somewhere ? Gets swedish language when using my old satbox. Thank you i changed to "preferred epg language" - swedish, in Options - EPG/Teletext. I get them in swedish så det funkar bra. Quote Link to comment
blomman Posted December 21, 2006 Author Share Posted December 21, 2006 i changed to "preferred epg language" - swedish, in Options - EPG/Teletext.I get them in swedish så det funkar bra. Thank you very much, missed that setting , works great now Quote Link to comment
Guest Lars_MQ Posted December 21, 2006 Share Posted December 21, 2006 4) Well I don't know what MCE does, I tried it, found it very annoying and never touched it again, maybe you can explain what you want? Quote Link to comment
blomman Posted December 21, 2006 Author Share Posted December 21, 2006 4) Well I don't know what MCE does, I tried it, found it very annoying and never touched it again, maybe you can explain what you want? It's a non-linear zoom on 4:3 content to fill up the widetvscreen. This link explains it very well Quote Link to comment
Guest Lars_MQ Posted December 21, 2006 Share Posted December 21, 2006 Ah yes we had this discussion before. We won't do it, cause it means recalculating the image and this is not acceptable. Quote Link to comment
blomman Posted December 22, 2006 Author Share Posted December 22, 2006 Well that's too bad. MS seems to handle it without performance/quality penalty, maybe it would be possible with a codec setting or a post processor some day... Quote Link to comment
Gioxy Posted December 22, 2006 Share Posted December 22, 2006 2) Download, install and use AC3Filter, it's a freeware great audio codec, with many useful options (editable in/out matrix included ) 5) DVBViever is most probably the faster channel changer you can find around , but some option can slow it: try to deselect "Automatic Channel Data Update" in "Settings / Options / TV + Radio"... Quote Link to comment
blomman Posted December 22, 2006 Author Share Posted December 22, 2006 2) Download, install and use AC3Filter, it's a freeware great audio codec, with many useful options (editable in/out matrix included )5) DVBViever is most probably the faster channel changer you can find around , but some option can slow it: try to deselect "Automatic Channel Data Update" in "Settings / Options / TV + Radio"... 2) Already using AC3 filter, great codec btw, spdif passthrough, i was hoping there was an option in DVBViewer that could remember that setting per channel You can't have kids fiddeling on codec settings can you 5) You're absolutely right, fastest channel switching pc software on the planet, but still would it be possible to speed it up even more. Comparing to my old satbox it's still slow... < 1 sec Thanks for the "Automatic Channel Data Update" tip, will try it. Quote Link to comment
