blomman Posted December 30, 2006 Posted December 30, 2006 Tried the new Version 3.6.0.1 and i think the "remember teletext subtitles per channel" function is broken. Need to reselect subtitle page on every channel change. Sometimes i need to wait before the wanted page is available... Worked fine (almost) in beta 3.5.0.121 support.zip Quote
Guest Lars_MQ Posted December 30, 2006 Posted December 30, 2006 subtitle code was not touched since .121. Quote
blomman Posted December 30, 2006 Author Posted December 30, 2006 Well something else must have broken it. Tried a fresh install/channelscan same problem teletext subtitle page is not remembered Back to 3.5.0.121 Quote
mitsu Posted December 31, 2006 Posted December 31, 2006 Well something else must have broken it.Tried a fresh install/channelscan same problem teletext subtitle page is not remembered Back to 3.5.0.121 I have no problems with subtitles. Quote
BelowSky Posted December 31, 2006 Posted December 31, 2006 Well something else must have broken it.Tried a fresh install/channelscan same problem teletext subtitle page is not remembered Back to 3.5.0.121 After you uninstall, delete the DVBViewer folder from Program Files. Then Install DVBViewer. Maybe it will work that way. Quote
blomman Posted January 2, 2007 Author Posted January 2, 2007 I have no problems with subtitles.What card do you have ? (I have a firedtv-s )Do you have Canal+ and teletextpage is remembered when switching back to a canal+ channel ? After you uninstall, delete the DVBViewer folder from Program Files. Then Install DVBViewer.Maybe it will work that way. Did a new attempt, uninstalled and deleted everything left in dvbview folder same result, telextpage is not remembered when switching channel Guess i'll be stucked with the beta... Quote
mitsu Posted January 2, 2007 Posted January 2, 2007 What card do you have ? (I have a firedtv-s )Do you have Canal+ and teletextpage is remembered when switching back to a canal+ channel ? I have Canal+ and the page is remembered. I have two cards: TT S2-3200 and Hauppauge Nova-T USB2. You must have some problem with the settings files. Try to delete the file where the teletext pages are stored (I do not remember which one). Quote
blomman Posted January 2, 2007 Author Posted January 2, 2007 I have Canal+ and the page is remembered. I have two cards: TT S2-3200 and Hauppauge Nova-T USB2. You must have some problem with the settings files. Try to delete the file where the teletext pages are stored (I do not remember which one). Thanks for the info did a fresh install, all settings = default and unchanged all i did was a channel scan on thor satellite... Anyone knows where the teletext pages are stored ? Quote
BelowSky Posted January 2, 2007 Posted January 2, 2007 (edited) Thanks for the info did a fresh install, all settings = default and unchanged all i did was a channel scan on thor satellite... Anyone knows where the teletext pages are stored ? Then maybe you should delete both DVBViewer from "Program Files" AND CM&V from "Application Data". Edited January 2, 2007 by BelowSky Quote
emmel Posted January 2, 2007 Posted January 2, 2007 (edited) No teletext subtitle pages are remembered here either (3.6.0.1). Never have been actually, which makes me wonder have I missed something? Anyways, this is not a big deal to me... Just wanted to confirm the observation of blomman. And what do you mean by "delete CM&V from Application Data"? CM&V is a registry key in HKEY_LOCAL_MACHINE used by DVBV, isn't it? Otherwise I can't find a reference from the documentation to such folder or file. Edited January 2, 2007 by emmel Quote
blomman Posted January 2, 2007 Author Posted January 2, 2007 Thanks for the confirmation emmel Did som more research using SQLite to dump the TVDatabase.db database where the subtitles are stored... Here are my findings: 1) After a channelscan and tuning to canal+ Mix: BEGIN TRANSACTION; CREATE TABLE channels ( idChannel integer primary key, strChannelID text, iCount integer); INSERT INTO channels VALUES(1,'1118568757|CANAL+ MIX (swe)',1); -cut- CREATE TABLE subtitles ( idChannel integer primary key, ONID integer, ServiceID Integer, TransportID integer, page integer, pid integer, sub integer, typ integer, TTXLang integer, Language text, caption text); -cut- COMMIT; 2) After selecting subtitle 199 on canal+ Mix BEGIN TRANSACTION; CREATE TABLE channels ( idChannel integer primary key, strChannelID text, iCount integer); INSERT INTO channels VALUES(1,'1118568757|CANAL+ MIX (swe)',2); -cut- CREATE TABLE subtitles ( idChannel integer primary key, ONID integer, ServiceID Integer, TransportID integer, page integer, pid integer, sub integer, typ integer, TTXLang integer, Language text, caption text); INSERT INTO subtitles VALUES(1,70,309,3,199,0,0,0,7,'GER','Teletext 199'); -cut- COMMIT; 3) After changing channel to canal+ Film 1 BEGIN TRANSACTION; CREATE TABLE channels ( idChannel integer primary key, strChannelID text, iCount integer); INSERT INTO channels VALUES(1,'1118568757|CANAL+ MIX (swe)',3); INSERT INTO channels VALUES(2,'1116340525|CANAL+ FILM 1 (swe)',0); -cut- CREATE TABLE subtitles ( idChannel integer primary key, ONID integer, ServiceID Integer, TransportID integer, page integer, pid integer, sub integer, typ integer, TTXLang integer, Language text, caption text); INSERT INTO subtitles VALUES(1,70,309,3,199,0,0,0,7,'GER','Teletext 199'); -cut- COMMIT; 4) After selecting subtitle 199 on canal+ Film 1 BEGIN TRANSACTION; CREATE TABLE channels ( idChannel integer primary key, strChannelID text, iCount integer); INSERT INTO channels VALUES(1,'1118568757|CANAL+ MIX (swe)',3); INSERT INTO channels VALUES(2,'1116340525|CANAL+ FILM 1 (swe)',1); -cut- CREATE TABLE subtitles ( idChannel integer primary key, ONID integer, ServiceID Integer, TransportID integer, page integer, pid integer, sub integer, typ integer, TTXLang integer, Language text, caption text); INSERT INTO subtitles VALUES(1,70,309,3,199,0,0,0,7,'GER','Teletext 199'); INSERT INTO subtitles VALUES(2,70,301,3,199,0,0,0,7,'GER','Teletext 199'); -cut- COMMIT; 5) After changing channel back to canal+ Mix BEGIN TRANSACTION; CREATE TABLE channels ( idChannel integer primary key, strChannelID text, iCount integer); INSERT INTO channels VALUES(1,'1118568757|CANAL+ MIX (swe)',4); INSERT INTO channels VALUES(2,'1116340525|CANAL+ FILM 1 (swe)',2); -cut- CREATE TABLE subtitles ( idChannel integer primary key, ONID integer, ServiceID Integer, TransportID integer, page integer, pid integer, sub integer, typ integer, TTXLang integer, Language text, caption text); INSERT INTO subtitles VALUES(2,70,301,3,199,0,0,0,7,'GER','Teletext 199'); -cut- COMMIT; 6) After changing channel back to canal+ Film 1 BEGIN TRANSACTION; CREATE TABLE channels ( idChannel integer primary key, strChannelID text, iCount integer); INSERT INTO channels VALUES(1,'1118568757|CANAL+ MIX (swe)',5); INSERT INTO channels VALUES(2,'1116340525|CANAL+ FILM 1 (swe)',3); -cut- CREATE TABLE subtitles ( idChannel integer primary key, ONID integer, ServiceID Integer, TransportID integer, page integer, pid integer, sub integer, typ integer, TTXLang integer, Language text, caption text); -cut- COMMIT; As you can see on 5) and 6) the subtitles record is deleted in the database when changing back to a channel with a subtitle already selected. Any comments from the developers maybe ? Attached a new support.zip from this install. support.zip Quote
retro Posted January 2, 2007 Posted January 2, 2007 Same problem here. Worked fine with previous beta. Quote
blomman Posted January 3, 2007 Author Posted January 3, 2007 Thanks retro, hope they fix this bug now Quote
Kurben Posted January 4, 2007 Posted January 4, 2007 Subtitles not working for me either in 3.6 version. I use DVB-T (Sweden) with teletext subtitles. The settings for the subtitles get deleted after channel change. Quote
lake Posted January 4, 2007 Posted January 4, 2007 Subtitles not working for me either in 3.6 version. I use DVB-T (Sweden) with teletext subtitles. The settings for the subtitles get deleted after channel change. Subtitles not working for me either in 3.6 version. I use DVB-S (Sweden) Canal+ with teletext subtitles. The settings for the subtitles get deleted after channel change. Quote
Guest Lars_MQ Posted January 4, 2007 Posted January 4, 2007 Subtitles not working for me either in 3.6 version. I use DVB-S (Sweden) Canal+ with teletext subtitles. The settings for the subtitles get deleted after channel change. How do you know they don't get saved if subtitles do not work for you? Quote
retro Posted January 4, 2007 Posted January 4, 2007 How do you know they don't get saved if subtitles do not work for you? Subtitles DO work when you select them, but the settings don't get saved between channelchanges. This worked 100% in previous beta. Quote
blomman Posted January 17, 2007 Author Posted January 17, 2007 Are you going to fix this bug or not ? Quote
mitsu Posted January 18, 2007 Posted January 18, 2007 Are you going to fix this bug or not ? It is already fixed. Download the current 3.6 final which is version 3.6.0.2 Quote
Kuidas Posted January 18, 2007 Posted January 18, 2007 Hello. I still have a problem with teletext subtitles. I use subtitles on four channels: TV1, TV2, YLE24 and TEEMA. If for example, channel TV1 is broadcasting teletext subtitles and I watch it, and then turn to TV2, there is a little problem. If there are currently no subtitles in TV2, the last subtitle from TV1 stays on the screen. support.zip Quote
blomman Posted January 18, 2007 Author Posted January 18, 2007 It is already fixed. Download the current 3.6 final which is version 3.6.0.2 Yepp you're right, seems to be fixed in 3.6.0.2 Didn't know a new version was available, was looking @ the Last Updated that says: 29.12.06... Big thanks to the DVBViewer team though Quote
