ramonchin Posted January 1, 2007 Posted January 1, 2007 (edited) Hi Is there any way to auto expand 4:3 video to 16:9?? I have a 16:9 lcd connected by HDMI-DVI cable and I need the TV remote to fix this (big black side bars). Thanks Edited January 1, 2007 by ramonchin Quote
niksu Posted January 1, 2007 Posted January 1, 2007 HiIs there any way to auto expand 4:3 video to 16:9?? I have a 16:9 lcd connected by HDMI-DVI cable and I need the TV remote to fix this (big black side bars). Thanks Same problem here. I have set DVBViewer starts in fullscreen mode. When I start the program there are black borders at both sides even if I had set aspect ratio setting to 16:9. When I visit to window mode and then back to fullscreen everything is okay(no black borders). Can you say what is wrong? Quote
ramonchin Posted January 3, 2007 Author Posted January 3, 2007 Please help us! Since more and more people hook HTPC to 16/9 LCD with HDMI or DVI connector, it's going to be a common problem. Most of these TVs don't expand 4:3 aspect ratio to full screen when DVI/HDMI channel is on. Thanks. Quote
hdv Posted January 3, 2007 Posted January 3, 2007 Hello, how it is, you use Aspect Ratio -> None Quote
Tjod Posted January 5, 2007 Posted January 5, 2007 I don't know if i understand you right but DVBViewer did not change the Picture. DVBViewer did not automatically stretch 4:3 to 16:9 or Zoom in if the TV-Station transmit 16:9 as 4:3 including black bars. But you make Zoom profiles Settings>Zoom or OSD->htpcHome>theSettings>Zoom Than you can build a Input command to exchanging the Zoom profiles via remotecontrol or one key. The commands are Zoomlevel Toggle (16394);Zoomlevel 0 (16390);and so on. Quote
