blomman Posted January 5, 2007 Posted January 5, 2007 Can you disable the built in subtitle support when viewing movies with .srt/.sub ? I prefer using vobsub for my subtitling and as you can see i got double subtitles , also timing is not correct in DVBViewer, delayed 200ms or something. Also noticed when using .sub/.idx there is a bug where subtitles is not transparent: Thanks Quote
andreasimner Posted February 13, 2007 Posted February 13, 2007 Can you disable the built in subtitle support when viewing movies with .srt/.sub ?I prefer using vobsub for my subtitling and as you can see i got double subtitles , also timing is not correct in DVBViewer, delayed 200ms or something. Also noticed when using .sub/.idx there is a bug where subtitles is not transparent: Thanks I am also interested in an answer for this question.... Quote
andreasimner Posted March 23, 2007 Posted March 23, 2007 Still no answer from the DVBViewer team.... Is there any way to achieve this? I am also interested in an answer for this question.... Quote
Argh! Posted March 24, 2007 Posted March 24, 2007 Hi, I've asked the same/similar in the German "Allgemeines DVBViewer Pro/GE" part on 6th March 2007 - using vobsub instead of built in subtitle decoder. No answer yet... Felix Quote
andreasimner Posted March 27, 2007 Posted March 27, 2007 Hi,I've asked the same/similar in the German "Allgemeines DVBViewer Pro/GE" part on 6th March 2007 - using vobsub instead of built in subtitle decoder. No answer yet... Felix Isn't there supposed to be some kind of support for a program when you have paid money for it? :-( Quote
mitsu Posted March 28, 2007 Posted March 28, 2007 Just rename or move the subtitile file so that DVBV does not find it Quote
andreasimner Posted March 29, 2007 Posted March 29, 2007 Just rename or move the subtitile file so that DVBV does not find it Unfortunally, that wasn't the issue here. I want to use Vobsub instead of the internal DVBViewer-subtitle engine so if I move or rename the subtitle file neither Vobsub or DVBViewer will find it and that isn't what I wanted. Or is there a subtitle file type "out there" that only Vobsub will recognise? Quote
mitsu Posted March 29, 2007 Posted March 29, 2007 Unfortunally, that wasn't the issue here. I want to use Vobsub instead of the internal DVBViewer-subtitle engine so if I move or rename the subtitle file neither Vobsub or DVBViewer will find it and that isn't what I wanted. Or is there a subtitle file type "out there" that only Vobsub will recognise? I may be wrong but seems that DVBV only accept subtitle file if the name is exactly the same only extension is different. Vobsub might accept little more different name. Try this. Second option: is there any way to take the vobsub titles from another directory? There are some options in vobsub settings. Quote
andreasimner Posted March 29, 2007 Posted March 29, 2007 I may be wrong but seems that DVBV only accept subtitle file if the name is exactly the same only extension is different. Vobsub might accept little more different name. Try this. Same rules apply for Vobsub unfortunally Second option: is there any way to take the vobsub titles from another directory? There are some options in vobsub settings. Don't know but a possible solution I was actually hoping that someone from the DVBViewer team would answer this question? Or have I posted it the wrong way? A simple "no" or a "yes" with a short explanation would do for me... Quote
