feucar Posted January 7, 2007 Posted January 7, 2007 After installation of 3.6.0 final the "Options" button in ChannelList window do nothing and channel detailed info don't show. To set tuning info i can only do a scan. Thanks Quote
hdv Posted January 7, 2007 Posted January 7, 2007 Hello, Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 Quote
Björn Rosberg Posted January 7, 2007 Posted January 7, 2007 Same problem here... The Channel list options usually opens the channel editor window, but it won't open in DVBViewer version 3.6.0 and 3.6.0.2. I'm using windows xp home edition. I can't use the support tool since I have moved back to version 3.5.0.1 again. Quote
ianred22 Posted January 7, 2007 Posted January 7, 2007 I have the same problem thought I was going mad 3.6.0.2 Quote
hdv Posted January 7, 2007 Posted January 7, 2007 Hello, @ ianred22, please take a look into the file setup.xml you can find this in the DVBViewer installation folder. Open the file in notepad and search this part (the DVBViewer must closed). - <section name="frmChannelConfig"> <entry name="Channellist">300</entry> <entry name="Headerheight">59</entry> <entry name="X">100</entry> <entry name="Y">32767</entry> <entry name="W">600</entry> <entry name="H">610</entry> </section> now you must change the line <entry name="Y">32767</entry> into <entry name="Y">100</entry> so the Channeledit window will show on screen. Edit: But you must edit the correct setup.xml please look here for more informations about the Usermode. Quote
ianred22 Posted January 7, 2007 Posted January 7, 2007 Great thanks all working. Really good product by the way ! support.zip Quote
Trifon Posted January 9, 2007 Posted January 9, 2007 Hello, Problem is with the new 3.6.02 version, the entire block "frmChannelConfig" is not present at all...... So, what to do??? Copy the section in question then past it??? Quote
feucar Posted January 10, 2007 Author Posted January 10, 2007 After setup.xml modification it's working. Thanks Quote
Bathman Posted January 12, 2007 Posted January 12, 2007 "Problem is with the new 3.6.02 version, the entire block "frmChannelConfig" is not present at all...... So, what to do??? Copy the section in question then past it???" I am having the exact same problem how did you get around it? Regards Quote
Tjod Posted January 12, 2007 Posted January 12, 2007 Make a backup from the setup.xml and try copy and past. Quote
Guest Lars_MQ Posted January 12, 2007 Posted January 12, 2007 this section is normaly created on first start of DVBViewer. So most likely your setup.xml is write protected or you look into the wrong file. You find your settings folder via DVBViewer -> Help -> Info -> versionsinfo there you can click onto the settingsfolder (just in the upper area of this window). Quote
Trifon Posted January 14, 2007 Posted January 14, 2007 (edited) this section is normaly created on first start of DVBViewer. So most likely your setup.xml is write protected or you look into the wrong file. You find your settings folder via DVBViewer -> Help -> Info -> versionsinfo there you can click onto the settingsfolder (just in the upper area of this window). Hello, Honestly, I don't underststand what you mean. I have installed the 3.6.0.2 version from scratch on Windows XP SP2 fresh install. The "option in chanel list" issue is present. Coming back to 3.5.0.1; everything is OK. I continue to believe there is some little bug. Cheers Edited January 14, 2007 by Trifon Quote
Fabien44 Posted January 27, 2007 Posted January 27, 2007 Hello, you must modify the setup.xml not in the install folder but in your local settings folder Quote
