kerschi Posted January 12, 2007 Posted January 12, 2007 (edited) hi i am owner of a DigitalRise DVB-C PCI Cable CI (2033) card i got the DVBViewer application basically up and running here without problems my cable provider streams these programs into cable: SD unencrypted: ORF, SAT1, PRO7, RTL,...... SD conax encrypted: KinderKanal, Premiere (They decrypt all Premiere streams and encrypt them with conax again!) HD unencrypted: Astra HD demo channel HD conax encrypted: (Where i have a permission with my card to view) Pro7, Sat1 HD Whatever encrypted (Standard Premiere encryption - they dont reencrypt premiere HD contents) Premiere HD Channels I do have a premiere abo and card and bought a TechniSat MultiCrypt 1 CI-Modul für Conax und Crytoworks CAM in SD i can view all unencrypted programs and the Premiere Programs i pay for => no problems in HD i can view the unencrypted Astra HD demo channel using the coreavc codec my problem: the Conax encrypted HD channels Pro7 and Sat1 don´t work i already talked to the technical guys of my cable provider and they told me the above info - which i do not fully trust my questions: is there any obvious reason why my setup should not be able to show me HD Pro7 and Sat1 ? when i switch channels to HD Pro7 or Sat1 how can i find out if the decryption works ? any clues where i should start investigations ? thanks for your help in advance support.zip Edited January 12, 2007 by kerschi Quote
Engelbert Posted January 12, 2007 Posted January 12, 2007 At present this one recommends himself for PowerDVD 6 as a video decoder of Cyberlink (better still 7, Trial suffices), the Ac3Filter paints both than an Audio decoder: http://www.soft-ware.net/multimedia/audio/...licht=AC3Filter And the Aufio-Renderer at 'Default DirectSound Device'! Quote
kerschi Posted January 16, 2007 Author Posted January 16, 2007 i installed the suggested audio codec... still no sound when i switch to the pro7/sat1 HD channels (when i switch to a SD channel with AC3 i have sound now) any idea where i should start investigations ? what info do you need to be able to help me ? Quote
kerschi Posted January 17, 2007 Author Posted January 17, 2007 some more info these screenshots were taken with transedit showing some details on the HD channels http://www.kerschi.at/dvb/dvb.rar i hope you can help me Quote
kerschi Posted January 18, 2007 Author Posted January 18, 2007 yesterday i was able to view pro7 in hd i played with the CI management tool provided by digitalrise while having DVBViewer running and suddenly pro7 hd showed up i wanted to check if sat1 hd also works... nope and when i switched channels back to pro7 hd i was not able to decrypt this again one-time success which shows me that my basic setup should work... but still there are problems with the decryption is there anything different with the decryption of HD nad SD channels ? i do have a premiere abo and when i switch to a premiere channel decryption works without problems please give me some advice where to investigate Quote
kerschi Posted January 18, 2007 Author Posted January 18, 2007 i just had an icq chat with my friend at my cable company he told me that he is currently in the process of development of a new settop box for HD currently they provide the original premiere hd box with an alphacrypt module (for nagra and conax) this box works but is not perfect for their customers the new box they are working on will have conax decryption embedded and currently they see the same behavour as i do with my technisat multicrypt module: sd channels in conax work without problems, hd channels without encryption do also work, but hd channels encrypted in conax don´t work has anyone of you also seen similar problems like this ? are there any tools which show me if decryption runs/works ? any debugging possibilities ? any advice regarding cams ? Quote
kerschi Posted January 18, 2007 Author Posted January 18, 2007 could it be that the problems i am seeing are related to what has been posted in this thread ?: http://www.DVBViewer.com/forum/index.php?s...=13895&st=0 if yes... is there already a solution available ? Quote
