Serban Posted January 18, 2007 Share Posted January 18, 2007 I have purchased the software in the hope that would work with my Digital Terrestrial hardware, but it seems that the hardware is not recognized. When I start the DVB Pro the message on the screen is that the hardware is not found. I have a Twinhan USB VisionPlus receiver which is correctly installed and recognized in the system properties as USB-DVB-T adapter and the manufacturer appears as "USBDTT Technology". The label of the device indicate: "TwinHan Technology Co. Ltd., Model Vision DTV USB Ter Model 7041." It appears that the software is compatible to the TwinHan Terrestrial Receivers. Can somebody help with this issue? Quote Link to comment
Tjod Posted January 18, 2007 Share Posted January 18, 2007 Du you have Installed BDA Driver? Is your card shown in Options>Hardware? Du you have perform a channel scan? Du have to a look at the DVBViewer Pro 3.6 Readme? Quote Link to comment
Serban Posted January 19, 2007 Author Share Posted January 19, 2007 Du you have Installed BDA Driver?Is your card shown in Options>Hardware? Du you have perform a channel scan? Du have to a look at the DVBViewer Pro 3.6 Readme? Thanks Tjod, It says on the drivers site that the model 7041 I have does not support BDA driver. Any suggestions? Thanks, Quote Link to comment
Tjod Posted January 19, 2007 Share Posted January 19, 2007 It says on the drivers site that the model 7041I did not noticed it.With out BDA driver the DVBViewer won't work. Quote Link to comment
