AndersB Posted January 27, 2007 Posted January 27, 2007 I would like to have a codec configuration tab in the options menu where I could configure the directx codec configured in DVBViewer for decoding audio and video. Most codec require the application to supply this configuration frontend but it seems DVBViewer does not offer this. So far, I've been using the codec configuration in Media Portal to set the codec configuration but it would be nice if DVBViewer would offer this. Quote
hdv Posted January 27, 2007 Posted January 27, 2007 Hello, no problem take a look at, View -> Filters -> ... Quote
AndersB Posted January 27, 2007 Author Posted January 27, 2007 ok, why am I not seeing that menu? My DVBViewer menu Quote
Gioxy Posted January 27, 2007 Posted January 27, 2007 It seems that DVBViewer isn't visualizing nothing... Please try again when a channel are tuned in an visualized... Quote
BelowSky Posted January 27, 2007 Posted January 27, 2007 It would be great if its there in the Right-click menu. Because, some times I want to watch it without exiting the full screen. Quote
AndersB Posted January 28, 2007 Author Posted January 28, 2007 (edited) I switched the display mapping and entered menu->view when DVBViewer was showing a tuned channel but still no such thing in my menu. It look exactly the same wether I open the menu from the primary display where the overlay is showing or the secondary display. Shouldn't I use the right-click menu? If so, what menu is the "main" menu and how to I access it? Edited January 28, 2007 by AndersB Quote
AndersB Posted January 28, 2007 Author Posted January 28, 2007 I changed the skin settings in DVBViewer to 'no skin' and tried all menu styles (-, DVBViewer and Vista) and with no skin the menu looks like this: DVBViewer menu without skin However, still no filter submenu. I use the 3.6.0.2 by the way. Currently, the filters installed are: Intervideo WinDVD audio/video dScaler 5 video FFDShow AC3Filter NVidia Purevideo video Quote
Derrick Posted January 28, 2007 Posted January 28, 2007 IMHO it was never possible with the Pro to get via right click -> menu to the filters This is possible though in the dvbviewer_GE. You have to go via the menu bar on top of the DVBViewer (view -> filters ->...) Quote
AndersB Posted January 28, 2007 Author Posted January 28, 2007 aha found it! thanks a bunch Then my feature request would be: Please fix access to filter menu from the right-click menu in DVBViewer Pro. Quote
Guest Lars_MQ Posted January 28, 2007 Posted January 28, 2007 Please fix access to filter menu from the right-click menu in DVBViewer Pro. There is nothing to fix. Only bugs need fixing. Quote
