Too much CPU load
dk1
I have tested 2 different applications for viewing HD channels
ALTDVB:
15mbit H264 channel -- CPU load 50-70%
20mbit H264 channel - CPU load 60-80%
DVBViewr
15mbit H264 channel -- CPU load 60-80%
20mbit H264 channel - CPU load 80-100%
tested on AMD4600+ x2, 2048 RAM, 500GB RAID5, ATI X1950XTX(512 RAM)
Codecs - Power DVD 7 - H264 accelerated decoder, Mainconcept AC3 decoder, VMR9
Why is DVBViewer taking that much CPU time? Is there anything what can be done othervise I am unable to watch some HDTV channels :)
Back to ALTDVB ??
please attach the support.zip
Which channels are you referring to? CI-module? (in case the channels are scrambled)
is VMR7 or VMR9 active in your DVBViewer? I my tests it caused around 20% more CPU load then pure overlay.
Perhaps try the dual core patch mentioned here be me several times.
cu B.
