antdude Posted February 2, 2007 Posted February 2, 2007 Hello! Is there a list of TV stations (doubt there are radio ones since I never heard of that) for Los Angeles, CA, USA? Thank you in advance. Quote
Gioxy Posted February 3, 2007 Posted February 3, 2007 ...broadcasted by which media? Cable, sat, radio wave or Internet? Quote
antdude Posted February 3, 2007 Author Posted February 3, 2007 ...broadcasted by which media? Cable, sat, radio wave or Internet? OTA (over the air)/antenna (e.g., bowtie). How does one do Internet? Quote
Gioxy Posted February 3, 2007 Posted February 3, 2007 For example, take a look in here: Penguin Radio... and, as you can see in the list, there was also "Internet Only" radio... simply follow the links to listen You wonder how I found it? I've simply Googled "los angeles" radio internet Quote
antdude Posted February 3, 2007 Author Posted February 3, 2007 For example, take a look in here: Penguin Radio... and, as you can see in the list, there was also "Internet Only" radio... simply follow the links to listen You wonder how I found it? I've simply Googled "los angeles" radio internet Interesting. So I will have to try that. I didn't know I could get digital radio off my bowtie antenna and DVBViewer. I thought only XM and Sirius had them (not free). Quote
hackbart Posted February 3, 2007 Posted February 3, 2007 I'm quite sure that you have atsc fta reception in los angeles. If you have one of those ATSC receivers (e.g. from http://bbti.us/) you should receive some channels. In your case: http://tvlistings5.zap2it.com/tvlistings/G...upId=PC%3a90013. Christian Quote
antdude Posted February 3, 2007 Author Posted February 3, 2007 I'm quite sure that you have atsc fta reception in los angeles. If you have one of those ATSC receivers (e.g. from http://bbti.us/) you should receive some channels. In your case: http://tvlistings5.zap2it.com/tvlistings/G...upId=PC%3a90013. Christian Yeah, I do that one: http://www.bbti.us/products_air2pc_atsc_pci.htm ... Just wanted to be sure my listings were same as others'. Now, the radio is still questionable. I will have to see if I can get those in DVBViewer. Quote
Gioxy Posted February 3, 2007 Posted February 3, 2007 I think I found what you are searching for: HD Radio list fort L.A.... Quote
antdude Posted February 5, 2007 Author Posted February 5, 2007 I think I found what you are searching for: HD Radio list fort L.A.... Um, stupid newbie question. Where do I do the radio stuff? I can't seem to find it. Quote
Gioxy Posted February 5, 2007 Posted February 5, 2007 the list in the middle of the page seems to be a list of L.A. hd (alas digital) radio station... ...isn't it? Quote
antdude Posted February 5, 2007 Author Posted February 5, 2007 the list in the middle of the page seems to be a list of L.A. hd (alas digital) radio station... ...isn't it? No, I meant in DVBViewer program. Where do I activate/use the radio stuff. I only can find the TV stuff. Quote
